What size tires?
Old Dec 6, 2006 | 06:52 AM
shittles's Avatar
Default What size tires?
What tire size should I be running on 16x7 f & 16x8 r wheels?
I got my wheels with used tires (which are now bald). I am assuming the tires are currently undersized (205/55 & 225/55).
Also, any suggestions on a good street tire (obviously hinges on tire size)? I currently have Advan A048's. I only drove on them for a month (maybe a 1000 miles), and as I previously stated, they are already bald. So I need to get a tire that will last and will provide good handling.
Thanks
Chris
Old Dec 6, 2006 | 07:21 AM
C45P312's Avatar
I think the reason why they are undersized is because you can't get A048s in the perfect size for your wheel combo.
Just call up Jim @ Tirerack and he'll set you up with the right tire.
Old Dec 6, 2006 | 08:21 AM
shittles's Avatar
Looks like I need a 245/45/16 for the rear and 205/55/16 in the front.
Tire rack doesn't have much of a selection in these sizes. I wouldn't mind getting the Michlin Pilot Cup Sports.....but they are a competition tire. I want something that will last more than a few thousand miles. Tire-easy.com carries the Dunlop Sp Sport 8000 in the sizes needed. I may go with those.
Old Dec 6, 2006 | 08:28 AM
FASTSIIK's Avatar
i run 225/50/16 in the front and 245/45/16 in the rear,on staggered rotas, but i have slight rubbing over some bumps. i have some pics if you want to see them.
Old Dec 6, 2006 | 12:01 PM
FF2Skip's Avatar
Chris, how much performance are you looking for? I can't really comment on how long or even how well they perform, but I'm running Falken RT-615's on my Volks. I think I paid $560 shipped for all four in 245/275 configuration.
Nevermind... not in the sizes you need.
Toyo has the T1R. It is reported to be an okay tire- much better than the T1S(had those and hated them). They have them in 225/245 in overall tire diameters that are close to the oem size(24.7" & 24.6"). This isn't as important to you as you can recalibrate your speedo(yellow box). Here's the [URL=http://www.toyo.com/docs/tires/product_spec.asp?lpid=18966&name=Proxes T1R
Old Dec 6, 2006 | 12:35 PM
shittles's Avatar
Thanks Skip!
Old Dec 6, 2006 | 02:08 PM
JeremyM's Avatar
grow balls, 255 rear
Old Dec 6, 2006 | 08:02 PM
WarrenW's Avatar
Have you thought about running the same size all around? I'm running 225/50's (Goodyear Eagle F1, GS-D3) on my stock AP1 wheels and I like the handling, much more stable.
Warren
Old Dec 6, 2006 | 08:07 PM
FF2Skip's Avatar
Warren
Not mo' stable than a 225/245 setup, my friend. That doesnt mean that you can't like the setup better than the stock one though.
Old Dec 6, 2006 | 08:35 PM
3312DC's Avatar
Falkns arnt avaliable in those sizes Skip... unfortuanatly
Id suggest either the 205-245 or 225-245. Only problem with the 225 up front is you will get alot more oversteer unless you have a bigger front sway bar...
you can get the Hankook RS-2 in either of those sizes in 16s for extremely cheap, less than 400 bucks shipped from www.edgeracing.com
