Mid-A Swap Meet Member Classified Ads in the Mid-A Region
FS -Turbo kit Partout
Old Sep 13, 2017 | 07:32 AM
liquidgsr's Avatar
Default FS -Turbo kit Partout
Best way to contact: Njami01@gmail.com
Shipping not included.
You can shoot me an offer on anything you may be interested and I will let you know if it is too low.
I have everything taken out, I just need to organize the parts as they are spread out between my garage and my parents house.
Turbo setup made 657hp and around 400+tq at 22psi on E85 using ID2000 injectors.
I recently went back to NA and I have a lot of parts I no longer need.
Brand new in box ap2 dual super tech valve springs and titanium retainers - $350
Ptuning turbo kit down pipe - $150
Ptuning turbo kit recirculating dump tube - $100
3" cutout -$40
3" turndown for cutout $20
ID2000s AP2 06+ S2000. Injectors and clips $850obo
ID1000s AP2 06+ S2000 Injectors and clips $250obo
Used arp head studs - inline pro verified that they are good. -$75
Ap2 2007 coil packs 40k on them $80
2000- 2005 fuel pump hanger with walbro 400 installed -$120obo
S2000 Turbo kit with engine mangement, all you need is injectors and fuel pump
1000 miles on kit
AEMv2 Engine Magement System 2006+ S2000 with Jumper Harness - $900
S2000 Kings Performance V2 Manifold wrapped in heat wrap- $950
S2000 Vband Dump tube (has hair line crack here it is welded to the vband) - $50
S2000 3" Vband Downpipe with cutout.This goes from the turbo to where the end of the cat should be) - $300
S2000 charge pipes w/Tial BOV flange and AIT bung
Oil Drain (see below)
Oil Feed
MAC 3 Port Boost controller
Continental Flex fuel sensor and harness
Oil filter relocation sandwitch adapter and oil filter adapter, no lines.
Omni 4 Bar map sensor
I also have a timing chain cover that has a burn attached to it, but will need to be cutout and another bung rewelded. The threads are bad. I have the oil drain line as well, but might need new AN fitting
liquidgsr
Forced Induction For Sale
Mar 28, 2018 10:33 AM
liquidgsr
13
Oct 10, 2017 06:43 AM
Heybluguy
41
Dec 4, 2014 11:00 PM
phui
13
Jul 22, 2012 01:15 PM
S2K:-)
35
Mar 20, 2007 05:24 PM
