NEED HELP ASAP
I have my AP2 Taillights on the way to replace the ones from my wreck and I need an AP1 RH for Body fitment, does anyone have an old one even if it broken lying around, I can buy or borrow.
Um... I think that's gonna require some pretty extensive modification. Check this out... AP2 Taillight Conversion
... unless you're getting AP2 quarter panels, too.
$260 for everything including the sockets, wiring harness, body washers and gaskets. I ended up cutting out the factory harness and soildering in the new one. The hardest part is finding the correct tool to make the cuts in the rear body panel. I found the easiest way to cut ,with what I have, was to drile holes around the perimeter of the stencil then make the connecting cuts using a flex shaft with a cutting wheel. After, I used a small porting bit to smooth and reshape the holes then sand paper wheel to finsh.
