MidWest S2000 Club Kansas, Nebraska, the Dakotas, Missouri, Iowa, and Minnesota
Thinking about e85
Old Apr 5, 2010 | 12:34 PM
Gamble's Avatar
Default Thinking about e85
Lower cost, more power, better engine life, cooler running temperature, longer lasting oil and plugs.
Why has no one done this?
Would anyone recommend it on a N/A stock car?
Old Apr 5, 2010 | 01:05 PM
mpetus's Avatar
Stock? No.
I wouldn't agree with the statement that it produces more power. It basically acts as a really high octane and therefore you can run a quicker spark and higher compression/more boost without detonation. I don't think the stock ecu would adjust itself far enough to extract any more power from changing the fuel only.
Is this also the fuel that requires the stainless fuel lines as well or am I off my rocker?
Old Apr 5, 2010 | 01:10 PM
Gamble's Avatar
I would need a new ecu, fuel pump, and bigger injectors. Any car made after like 1986 has the right rubber in the fuel lines to not be corroded away.
Since I would need a new ecu, I could change ignition timing and a few other things as well. If I'm not mistaken, you can gain 25-35 hp with this depending on bolt-ons.
Old Apr 6, 2010 | 05:35 AM
g352s2k's Avatar
Joey has E85 and its proven that it makes powa.
Old Apr 8, 2010 | 07:57 PM
ILoveMYHonda1984's Avatar
I wouldn't waste the time or money on it na. Save up for boost, then get e85.
regray1
Aug 25, 2016 10:07 AM
mmm...vtec
Nov 14, 2009 12:39 PM
WalkingDrunken
Jul 6, 2006 06:21 AM
vader1
Jun 16, 2004 12:24 PM
Wildncrazy
Jul 3, 2003 05:58 AM
