NEED HELP
Ok so im having an issue on the dyno with my motor. Its a f24c (hybrid build NOT BC). Fully built with gt28rs. 8:8.1 Compression. Just to give everyone a heads up this is NOT AN S2000. But it does have a fully blown S2000 motor in it
When getting into peak power bands (around 5k+) were getting an ignition problem. The car has Okada Project Coil packs, and NGK iridium's. Ive read a few things about Okadas "plasma lift" which is basically a misfiring solution but its $400+. Ive tried a different set of plugs and switching the coil packs around. Im getting some spotty plugs as well in certain cylinders. I called the original tuners of the car in Cali and was told to check the Coil Pack Dwell parimeters. If anyone has had this problem or or a possible solution please let me know..i dont get online to much so shoot me a call 702-379-1207 (jordan)..thanks guys!
You need to PM this guy https://www.s2ki.com/forums/index.php?showuser=29177 or ask in the FI section of the board.
Dats2k
Apr 9, 2014 11:50 PM
