Nevada S2000 Owners Las Vegas, Nevada and area
need help with install on saturday {29th}
Old Sep 6, 2009 | 07:38 AM
oldsoldier's Avatar
Old Sep 13, 2009 | 05:45 PM
RB-What?'s Avatar
Originally Posted by Driven,Aug 30 2009, 12:22 PM
Just leave it unplugged...
As mentioned earlier...
For Driver belt:
Left lap belt, mount behind the seat to the floor using a bolt and a 2.5"x2.5" steel backing plate.
Right lap belt can be mounted to transmission tunnel (best), or to the seat bracket where the factory seat bucket mounts to.
Sub belt (which you should absolutely use), mount to the floor under the seat where the sub belt hole would be. use the 2.5" steel backing plate for this as well.
Shoulder belts should be mounted to the rollbar.
Although this is in my old CRX, harness mounting is the same regardless of vehicle:
For the shoulders. You can see the difference between the Y shoulder harness (passenger side) vs. the dual shoulder harness (driver side... and the ideal design).
Some good info on harnesses:
http://www.hmsmotorsport.com/docs/Competit...nstructions.pdf
How you mounted your shoulder belts is very unsafe!! Shoulder belts harnesses should be no more that 2-4 inches below your shoulders. Puts pressure on your spine and could potentially break your back in a car accident.
Old Sep 14, 2009 | 10:12 AM
Driven's Avatar
the angle of the picture makes it seem VERY VERY low (it's not).
Old Sep 14, 2009 | 10:24 PM
s2k_ed's Avatar
ahhhh crx.... i miss my ef9 it got stolen 1 month after i slapped the supercharger on it...
tbell ncsu
Sep 3, 2015 12:20 PM
WillieG
Jacksonville
Mar 22, 2011 11:42 AM
TriaXenginE
29
Aug 29, 2008 10:04 PM
topcat7111
Jul 30, 2005 11:01 PM
kush only
Apr 5, 2003 12:31 PM
