Nevada S2000 Owners Las Vegas, Nevada and area
Need tires for track
Old Feb 14, 2005 | 10:01 PM
VegasVic's Avatar
Thumbs up Need tires for track
Hey i am planning on attending the autocross event but i really dont want to run on my good tires and rims. I was wandering if someone knows where a junk yard or salvage yard is so maybe i can just pick up some beater tires to kill. thanks for any reply.
Old Feb 15, 2005 | 12:58 AM
KrazyKarim's Avatar
Uhhh you want to use good tires genius
Old Feb 15, 2005 | 01:37 AM
RACER's Avatar
You dun't want to put mix-match tires on this car. At least if they came off an S2K, due to antilock brakes, that would rule out flat spots. But still, I would prefer new rubber in quantities of two or four.
The problem with used tires on a car like this, unless you find two or four tires that came off the same car, your looking at mis-match in terms of overall wear and wear characteristics (from one tire to another) as well as hardening from age and or heat cycling. If the car that the tires came off didn't have antilock brake, if you drive like a maniac like me, then they will probably have flat spots on them.
A used tire that is out of round will cause vibrations on this car whether it is balanced or not.
Old Feb 15, 2005 | 03:12 AM
KrazyKarim's Avatar
Racer It's for his civic but I do agree with you said
Joe your current tires on your car will work fine. Your not drifting and since it's your first autocross you probably won't be going fast enough to destroy a set of tires. As long as your street tires have some tread and hold air they should be good to pass tech so you won't have a problem with that either. Your going to want to bump them up a few PSI to keep them from rolling over onto the sidewalls but we'll talk about all that on Wed at dinner.
This is your first autocross don't worry about the parts on the car. Concentrate on learning the line and having a good time and you'll do fine
If you end up enjoying it then you can look into getting a set of go fast tires
Old Feb 15, 2005 | 06:37 AM
VegasVic's Avatar
very true. ok thanks a bunch both of you.
Old Feb 15, 2005 | 08:06 AM
Zzyzx's Avatar
Ya, Dont worry too much about it yet... and remember, We can still trade cars for a few runs if you want. I'd like to see how a relitivly stock Civic handles...as mine was never stock.
Old Feb 15, 2005 | 09:01 PM
VegasVic's Avatar
haha i just put my magnaflow exhaust on tonight. I love it. its not too loud but you can still here it. Spence that would be cool. Are you going to meet up at karims house?? I am
Old Feb 15, 2005 | 10:10 PM
Zzyzx's Avatar
Sadly, when you guys are meeting up at Karims @ 7:00 I'll allready be at the track making sure the timing trailier shows up, the track is being setup and such...
jchan727
Oct 29, 2012 08:51 AM
gatorbait4me2000
Jul 13, 2011 11:23 PM
starbai
South Florida
Sep 24, 2007 02:04 PM
BerlinaBayRidah
Aug 5, 2006 09:36 PM
Lice Locket
Mar 22, 2006 05:12 AM
