Engine Oil Question
Old Mar 27, 2012 | 06:01 AM
Vinny_GPW-S2K's Avatar
Default Engine Oil Question
At first I was thinking of getting Mobile 1 10W-30 just now I came across one of the post about Amsoil SSO 0W-30 and thought maybe I'll just go with that. Any suggestion regarding this matter or have anyone on here uses it as well? Also when you guys recycle your oil you can't mixed them up with any other oil example transmission fluid or differential fluid correct since this will be my first time doing the oil change? Last of all where can I purchase Amsoil product beside online purchase?
Old Mar 27, 2012 | 06:12 AM
RedSunS2K's Avatar
http://www.amsoil.com/locator/index.aspx
Type in your zip code. Call the nearest dealers.
Old Mar 27, 2012 | 06:19 AM
Thanks now I can't decided what oil to use since there another oil on my list as well Royal Purple what do you used on your S RedSunS2K?
Old Mar 27, 2012 | 06:34 AM
Mr.60trim's Avatar
Mobil 1 10w30 syn since day 1 for me. Be sure to use the s2k spec'd OEM oil filter as well15400-PCX-004).
Old Mar 27, 2012 | 10:09 AM
RedSunS2K's Avatar
I use this ever since I turbo'd.
Old Mar 27, 2012 | 04:36 PM
CT S2K's Avatar
Amsoil 10w-30 with OEM filter. if your S has over 20k miles and transmission and diff has not been change, recommend doing so. just pro longs life and fluid is cheap. used oils can be mix but can not mix them with coolant.
Old Mar 28, 2012 | 05:27 AM
grovefromnh's Avatar
Mobil 1 oil filter
Mobil 1 oil filter
Old Mar 28, 2012 | 05:45 AM
Kenneth Noisewater's Avatar
OEM filter and Royal Purple for me
Old Mar 28, 2012 | 06:11 AM
Thanks for the info guys...
