Espelir Spring Install
It rides a bit more firm, but not unreasonable. The best way to tell is to drive it for yourself.
They were easy to put in....6 bolts per side on the front, 3 per side on the rear to get the shock/spring assembly in and out, then some time with a spring compressor...
Jeff , Great job on getting your springs in
Did you remember to cut the bump stops?
Did you preload the suspension before you tightened everything?
I am not trying to discourage you ,just trying to help and make sure you get the most out of your suspension.
Looks like she is sitting the same as my 1" drop . It does take a few weeks for it to settle and should sit another 1/4 to 1/2 inch lower .
