Help
Old Jun 3, 2012 | 05:15 PM
Nand01's Avatar
Default Help
Hey guys, I have already made a post in "under the hood section" no luck yet, I have a 03 S. After putting new tires on the car has developed a shake/vibration. Between 60-80 today I noticed that while on 5th my shift knob was shaking ALOT but the car was riding smooth. Ive bought half shaft spacers since the car is lowered. Also changed the tires and balanced them 3 times.... Any input or maybe I can meet with someone to inspect my car. I have no problem driving. Im in Bridgeport CT, Thanks in advance.
Old Jun 3, 2012 | 05:24 PM
SilverS2kF22C1's Avatar
Motor mount? Typically rip on the passenger side. Will be wet if it happened recently.
Sent from my DROIDX using Tapatalk 2
Old Jun 4, 2012 | 07:45 AM
Bass's Avatar
shake after new tires? did your aftermarket rims have hubcentric rings on them?? maybe the installer forgot to put them back on
are the tires bad?? could be one bad tire slipped a belt or something - try posting in ethe tire and wheel section
Old Jun 4, 2012 | 09:15 AM
Bass's Avatar
think it could also be an alignment
Old Jun 4, 2012 | 06:08 PM
Legal Bill's Avatar
If you can't find anything obvious, try swapping wheels and tires with another car and see if it goes away. Kind of a PITA, but it should only take an hour to swap, test drive, and then swap back. Then you'll know if it is the wheels or tires without spending any $$. If it does go away with the wheel and tire swap, swap back one wheel at a time and go for another test to find the one that is bad.
Old Jun 4, 2012 | 08:13 PM
Nand01's Avatar
Hey guys, so today I got to a lift, Turns out that the passenger motor mount was blown. Completely flat, so I searched on craigs and found a guy with a mount for and also got a bunch of sensors and goodies. If you need something lmk. Got alternator oil pump water pump bunch of sensors and hoses. A/c compressor. Spark plug cover
Old Jun 5, 2012 | 03:51 AM
I win!
Glad to hear it was the mount and sounds like you got a good deal on a new one too (under hood thread)
Old Jun 5, 2012 | 04:45 AM
Lainey's Avatar
Originally Posted by SilverS2kF22C1
I win!
Good call, Scott!
Old Jun 5, 2012 | 05:43 AM
Nand01's Avatar
Good call Scott, It was heck of a deal, most of these parts look new and have caps on all the openings. Thanks again guys.
Old Jun 5, 2012 | 10:34 AM
Nand01's Avatar
NOOOOOO the stupid shake came back F****** now im lost, now someone said diff fluid, also check the back wheels if they have play.... HELP!
