Hey Erick!
What do you know about this:
Which parameters and settings does the DSL Speed Optimizer modify?
1. TCP 1323 Extension - This parameter enables enhancements to the TCP/IP protocol that provide improved performance over high-speed connections.
2. TCP Receive Window - This parameter specifies the number of bytes a sender (the source you are downloading from) may transmit without receiving an acknowledgment.Modifying it determines the maximum size offered by the system.
3. MTU (Maximum Transmission Units) - The MTU defines the largest single unit of data that can be transmitted over your connection.
According to Verizon, I pay for the 3mbps DSL, according to a speed test, I'm getting 1.486.
I gave up talking to them, all they want to know is "do you have a filter on your phone."
Assuming my connection is actually the one I'm paying for, is there a way to get what I pay for, speed wise??
Just curious. The DSL is actually fine as it is for me, and it's still totally free for three more months, due to the PIA I dealt with with modem issues.
Originally Posted by elmmx5,Feb 18 2009, 05:37 PM
You can do that and it might speed things up a tiny bit, but it's not going to double your speed.
Where and how are you checking your speed now?
Originally Posted by zzziippyyy,Feb 18 2009, 07:34 PM
dont be messin with the mtu if your using verizon, if you do it will mess you up. 1492 is where it should be
But I'm paying for the 3 mbps. Should I not be getting a higher number when testing?
SpeedTest.net
Also, like I suggested to Dave in the Vintage Forum, go to dslreports.com and run their tweak tests. They will recommend any changes you may need. Of course, YMMV.
sometimes something that sounds better isnt.
Originally Posted by jukngene,Feb 18 2009, 07:54 PM
Did you try this test? I find it pretty reliable.
SpeedTest.net
SpeedTest.net
Originally Posted by zzziippyyy,Feb 18 2009, 07:57 PM
messing with the mtu setting will affect you in a negative way. From my poor memory tweaking this setting will result in email failure.
Just wondering why, if I'm paying for the more expensive connection, would I not be getting it?
Though I am getting more than the 1 mbps, which is the other plan.
Or is this like the old modem issue...you could have a 56K modem(or whatever it was), but your connection speed varied based on many other factors.
