I need less understeer!
Old Jul 3, 2003 | 11:25 AM
s2ktaxi's Avatar
I had my car aligned to UK specs last week and was able to drive about 15+ runs at the BMWCCA Test and Tune last Saturday. Here are some observations:
My before alignment settings were a bit off from factory specs but still reasonable.
I went within 0.16" total toe for the rear which is the minimum. I don't like too much tire scrubbing in the rear to increase feel. Though, this increases the likelihood of oversteer, the rear felt very planted.
Overall, the rear end was much more planted than before and even more so than the '02 suspension. The '01 with the UK specs has a higher limit and is just as easy to control/countersteer. Turn in was sharper in my current setup than in a stock '02. Probably has to do with the softer bushings and softer front sway bar in the '02.
The thing I did not like is that I got more understeer than I would have liked. The rear felt like it had far more grip than the front. I will probably increase front camber to 1.25 from 1.00 degree to get a bit less understeer.
I strongly recommend the UK alignment spec for those of you with '00-01 S2000s. It raises your cornering limit and makes the car safer under power. The only downside is more inside tire wear...
Old Jul 3, 2003 | 12:52 PM
ChrisfromRI's Avatar
Once you put track tires on the front (225/50) and the rear at (245/45), you will probably be wishing for understeer...
Kind Regards, Chris
Old Jul 3, 2003 | 01:40 PM
s2ktaxi's Avatar
but since I don't run R rubber... I need a bit less understeer...
Old Jul 3, 2003 | 06:56 PM
mas's Avatar
mas
[QUOTE]Originally posted by s2ktaxi
[B]I strongly recommend the '02 alignment spec for those of
Old Jul 3, 2003 | 08:07 PM
s2ktaxi's Avatar
Originally posted by mas
I think you meant to say you recommend the "UK alignment specs".
You're right - corrected...
Old Jul 4, 2003 | 12:41 PM
honda_s2k's Avatar
Francis,
Sounds like what I am looking for. What alignment shop do you recommend?
Old Jul 4, 2003 | 03:12 PM
s2ktaxi's Avatar
Bill and I have been using DirectTire. I was in Watertown and Bill in Norwood.
Old Jul 5, 2003 | 01:38 AM
demonderrick's Avatar
hey, Francis, what about the 01 with Mugen front sway bar..??
Old Jul 5, 2003 | 05:40 AM
s2ktaxi's Avatar
Did not try to drive that combo at the autocross, but it would give me even more understeer.
Old Jul 5, 2003 | 07:14 AM
Pinky's Avatar
Did you lap times improve with the UK alighnment specs?
For less understeer then you need to either adjust your alignment or do a softer sway bar. Pickup an '02 sway bar or have you done this already?
Though you already knew that.
