Still having some issues after hitting curb!
Old May 28, 2013 | 02:52 PM
the GTR's Avatar
Default Still having some issues after hitting curb!
I replaced the upper control arm, lower control arm and knuckle. And today i went to get a alignment after installing the parts my self and they told me that there was still something bent in there but i cant see what it is plus the car is driving fine. Help me out here is the sheet they gave me
Old May 28, 2013 | 02:57 PM
the GTR's Avatar
Noteworthy: the strut was a real bitch to put back with the new parts... Makes me wonder if it is bent or thats just the way it is.. I had to unbolt the lower control arm and bolt the strut to arm first and then force everything back into place.
Old May 28, 2013 | 05:07 PM
Mongo84's Avatar
I would check the rear subframe, make sure its not bent, it may also have shifted on you depending on how lose the subframe bolts were. I have heard that have a habit of backing out overtime depending on the year of the car. I would also not trust town fair but that is just my prefrence
Old May 28, 2013 | 07:45 PM
AZfury's Avatar
The s2000 has fully adjustable suspension, the rear will def adjust to spec but you have a front caster issue...your subframe could be pushed back a little, if you need an alignment done let me know, we have a nice flush to the floor alignment rack here at Honda
Old May 28, 2013 | 07:47 PM
AZfury's Avatar
Fix your bad balljoint though
Old May 28, 2013 | 07:48 PM
the GTR's Avatar
Pmed
Old May 29, 2013 | 03:41 AM
SilverS2kF22C1's Avatar
Did you replace the Toe bar with the A-arms? That could be bent too causing an issue...
Old May 29, 2013 | 05:56 AM
the GTR's Avatar
Is that the bar thats under the lower control arm on the caliper side.. I didnt replace that one
Old May 30, 2013 | 02:46 AM
summitrider2012's Avatar
If you look at the specs they didn't even adjust the rr and barely adjusted the lr
Sent from my iPhone using Tapatalk
Old May 30, 2013 | 05:52 AM
the GTR's Avatar
I will be replacing the toe arm and ball joint and see what they do to it if they come with that bs.. Im going to drive to ma so AZ can take a look a it
