Stuck silencers, any ideas?
Old Jun 16, 2009 | 12:30 PM
HARDtoTOP's Avatar
Thumbs up Stuck silencers, any ideas?
I want the silencers out of the Invidia now that I am not commuting to school anymore. They are stuck in there REALLY good.
I have tried every trick I can think of except using a torch to make the tip red hot and expanded to get the silencers out because they will be relatively cooler and less expanded. This is a last resort because I really don't want to have to drop the exhaust to do it.
So far I have tried the following:
-WD40 the hell out of it
-Grabbing the silencer with a vice grip and hammering out
-Grabbing with vice grip and try twisting motion
-Using a a 5lb slide hammer with a bit that grabs the inside of the silencer pipe
No joy.
Before I light up the torch, can anyone think of a better way?
Old Jun 16, 2009 | 12:34 PM
zzziippyyy's Avatar
How did you finally get them out at Bill's brake meet?
Old Jun 16, 2009 | 12:35 PM
TProuty's Avatar
buy PB Blaster Penetrating Catalyst
Bass's Avatar
pb blaster is 100* better than wd 40
spray it for a few days it should come right out
Bass's Avatar
Old Jun 16, 2009 | 12:36 PM
TProuty's Avatar
damn... same too....
Old Jun 16, 2009 | 12:48 PM
silex's Avatar
What I use is the perfect metal stick with a nub sticking out, one of those Kragen/Autozone jack handles.
Old Jun 16, 2009 | 12:53 PM
SI JASON's Avatar
Slide hammer with a hook on it. get a pc of metal bigger then OD of the silencer and pull out. If that dont work then somethings wrong. I can do it for ya if you dont have the tools or such.
Old Jun 16, 2009 | 01:40 PM
HARDtoTOP's Avatar
I did the slide hammer thing already with a special end piece that can lay flat but it pivots to grab the interior of the pipe which it did. I slide hammered it so hard the exhaust almost came off the car
I think from heat cycling so many times, the silencer has fused to the pipe a little bit. I will soak it in PB to see if it does it. Otherwise I am going to drop it an torch the crap out of it. You can get anything out with heat.
Old Jun 16, 2009 | 01:41 PM
Cubs2k's Avatar
LOL...Sell it and go TI-C!! Never had the silencers in!! LOL
