throttle response
Old May 14, 2009 | 02:53 PM
  #31
SI JASON's Avatar
Check your spark plugs? I had to replace mine they were shot. ANd car runs much much better now.
Old May 14, 2009 | 05:04 PM
  #32
Cubs2k's Avatar
MAP?
Old May 14, 2009 | 05:23 PM
  #33
Bass's Avatar
good suggestion cubs!
Old May 15, 2009 | 03:14 AM
  #34
boltonblue's Avatar
how about plane old air filter check?
get rid of the mouse nest in there and it will do much better.
Old May 15, 2009 | 03:34 AM
  #35
TProuty's Avatar
Just bought a new one back in November, K&N. I'll see if needs to be recharged.
Old May 15, 2009 | 03:36 AM
  #36
TProuty's Avatar
Originally Posted by Cubs2k,May 14 2009, 08:04 PM
MAP?
what would this be? what would be a fix?
Old May 15, 2009 | 03:37 AM
  #37
ScottyBallistic's Avatar
Plugs first
Checking the filter is also a good idea . If you tighten the throttle cable make sure you leave some slack for the throttle to close alll the way .
Also make sure you dont have a vacuum leak anywhere
If everything else looks good . Disconnect the battery to reset the ecu . Then let her fully warm up after starting then take a normal drive for about 10min . then you can play and see if it is better
If not the EU Black will give you all the throttle response you need
Old May 15, 2009 | 03:50 AM
  #38
TProuty's Avatar
I'm thinking about it... lol.....
I just found this... so I'll give this a shot too.
https://www.s2ki.com/shared/library/...-073/index.htm
Old May 15, 2009 | 04:18 AM
  #39
gilbertg's Avatar
Chrome is cheaper, similar throttle response but less cool features...
Old May 15, 2009 | 04:52 AM
  #40
TProuty's Avatar
Yea, after reading the post about the chrome I said to myself "this is what i want" but I'm in the process of looking/buying a house so I need to put that on hold.
