Anyone able to check a VIN for me???
Old Nov 12, 2001 | 08:28 PM
S2K's Avatar
S2K
Default Anyone able to check a VIN for me???
The VIN is 1B4HS28Y8XF543541.
Thanks in advance.
Old Nov 12, 2001 | 10:14 PM
YoungS2K's Avatar
* GOOD NEWS!
Carfax search results confirm this 1999 Dodge Durango 4X4
(1B4HS28Y8XF543541) qualifies for the $5,000 Carfax Clean Title History
Guarantee. By ordering this Carfax Report, you have significantly reduced
your risk of purchasing a vehicle with a costly hidden problem.
Sect.# Section Name Section Results
1 Vehicle Specifications 1B4HS28Y8XF543541
2 Title Check Clean Title History Guaranteed
3 Odometer Rollback Check No Odometer Rollback Detected
4 Problem Check No Problems Found
5 Registration Check Checked 7 types of vehicle
registrations
6 Vehicle History Details 2 Total Vehicle History Records Found
NOTE: Carfax has not inspected this vehicle. It may have problems that
have not been reported to Carfax.
How Carfax analyzed this vehicle's history:
Carfax checks the VIN against its nationwide database containing
over 1.54 billion vehicle history records. The Carfax database
includes U.S. and Canadian title and registration activity, rental and
lease usage, odometer readings from inspection stations, auto auctions
and other sources.
SECTION 1 CARFAX VEHICLE SPECIFICATIONS
Vehicle ID: 1B4HS28Y8XF543541
Yr/Mfg: 1999 Dodge Durango 4X4
Model: Durango 4X4
Body: 4D Sp Ut Utility
Engine: 5.2L V8 SMPI OHV 16V
Fuel: Gasoline
Driveline: 4-wheel Drive
Aspiration: Normal
Country Mfg.: United States
SECTION 2 TITLE CHECK
* RESULT: GOOD NEWS!
Guarantee. Carfax analyzed this vehicle's title history to determine if
any title documents were designated or marked with the following problems:
Problem Titles Checked: Results:
Salvage/Junk-------------------------> No Salvage/Junk Title Found.
Rebuilt/Reconstructed----------------> No Rebuilt/Reconstructed Title Found.
Flood Damage-------------------------> No Flood Damage Title Found.
Damage Disclosure--------------------> No Damage Disclosure Found.
Manufacturer Buyback (LEMON)---------> No Manufacturer Buyback Found.
Exceeds Mechanical Limits (EML)------> No EML Found.
Not Actual Mileage (NAM)-------------> No NAM Found.
SECTION 3 ODOMETER ROLLBACK CHECK
Carfax search results on this 1999 Dodge Durango 4X4
(1B4HS28Y8XF543541) did not uncover a potential odometer rollback. Carfax
analyzed this vehicle's reported odometer readings to determine if any
reading is less than a previously reported reading.
Date Reported: Odometer Reading:
11/03/1998 124
SECTION 4 PROBLEM CHECK
(1B4HS28Y8XF543541) did not uncover any of the following problems:
Problems Checked: Results:
Accident-----------------------------> No Accident Record Found.
Salvage Auction----------------------> No Salvage Auction Record Found.
Failed Emissions Inspection----------> No Failed Emissions Record Found.
Fire Damage--------------------------> No Fire Damage Record Found.
Crash Test Vehicle-------------------> No Crash Test Vehicle Record Found.
Grey Market Vehicle------------------> No Grey Market Record Found.
SECTION 5 REGISTRATION CHECK
FYI: Carfax search results on this this 1999 Dodge Durango 4X4
(1B4HS28Y8XF543541) identify the types of state motor vehicle department
registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease--------------------------------> No Lease Registration Found.
Rental-------------------------------> No Rental Registration Found.
Government---------------------------> No Government Registration Found.
Taxi---------------------------------> No Taxi Registration Found.
Fleet--------------------------------> No Fleet Registration Found.
Commercial---------------------------> COMMERCIAL REGISTRATION FOUND.
Non-Profit---------------------------> No Non-Profit Registration Found.
SECTION 6 VEHICLE HISTORY DETAILS
The Carfax database contains a total of 2 vehicle history records on this
1999 Dodge Durango 4X4 (1B4HS28Y8XF543541).
Date: 10/01/1998
Information Source:
Iowa Motor Vehicle Dept.
Milwaukee, WI
General Comments:
Registered as commercial vehicle
Date: 11/03/1998
Odometer Reading: 124
Information Source:
Milwaukee, WI
Title #53W093247
General Comments:
Title issued
NOTE: You have significantly reduced your risk of purchasing a vehicle with
a hidden problem. However, Carfax has not inspected this vehicle. There
could be other potential problems with this vehicle that have not been
reported to Carfax.
NOTE: Not all titles issued represent a change in vehicle ownership. For
example, a title could be issued to reflect an address change or correction.
|THE CARFAX $5,000 CLEAN TITLE HISTORY GUARANTEE |
|A Three-Year, Transferable Protection Plan |
|Carfax's $5,000 Guarantee confirms this 1999 Dodge Durango 4X4 |
|(1B4HS28Y8XF543541) has a Clean Title History. This certificate is valid |
|for three years from date of issue, and is transferable! |
|$5,000 CLEAN TITLE HISTORY GUARANTEE TERMS: |
|VIN: 1B4HS28Y8XF543541 |
|Yr./Make/Model: 1999 Dodge Durango 4X4 |
|Issue Date: 11/13/2001 |
|Expiration Date: 11/13/2004 |
Old Nov 13, 2001 | 06:39 AM
S2K's Avatar
S2K
YoungS2K: Thanks again...I guess I'll be picking this Durango up later this evening...
RA31125
Sep 29, 2004 08:36 PM
Old School s2k
Apr 16, 2003 08:07 AM
misternapps
Mar 3, 2003 06:46 PM
lehighwiz
Dec 16, 2002 04:50 PM
DJ Qube
Mar 20, 2002 05:46 AM
