Bizarre Job postings
Old Sep 30, 2002 | 06:17 PM
WestSideBilly's Avatar
Default Bizarre Job postings
Well, I'm back to semi-actively job hunting, and I was really blown away by how odd some of the postings are...
Our client is a very high profile manufacturer of construction and industrial equipment. They are investing now in new products for the next market cycle. They are located 17 miles from a super fishing lake, and hunting is all around.
Fishing and hunting as an incentive?
We need engineers (BSME's) with the forethought, initiative, technical expertise, and communication skills to change there current situation. This is for the engineers that want to improve their career. If you are searching for a better opportunity than the one you have now, please email your resume in a word document asap.
Keywordsowertrain suspension engine motor FEAD torsional crank valve axle joint bushing mount seal system brake wheel bearing gasket damper rubber plastic metal forge forging NVH noise vibration shock strut spring bond adhesive sealant acoustic lip dynamic static oil elastomer polymer drive train axle plastic polymer rubber elastomer shock vibration isolator isolation damper bushing federal mount seal power train teflon lip coupling axle velocity boot transmission static engine bearing suspension piston cam valve gasket sealing dynamic powertrain steering wheel corner brake federal train valvetrain bonded metal stamp ring vvt vct
Can you say "resume whoring" ? There are no real jobs attached to these postings, just a company trying to get as many resumes as feasably possible...
Bleah, I could go on and on... I forgot how frustrating this was
S2Gizzle
Jan 11, 2006 11:56 PM
WarrenW
Sep 6, 2005 08:49 AM
Eze8199
Oct 3, 2002 07:01 PM
