Brush Teeth Question... Toothpaste In or Out?
Old Aug 21, 2006 | 06:31 PM
Riceboi's Avatar
My grandparents can walk around the house, watch TV and wash dishes while brushing there teeth and not spill anything. It's wierd really and funny!
Old Aug 21, 2006 | 06:48 PM
Shannon's Avatar
Yep, girls are clean, guys are messy My dad takes the cake... he leans over the sink the whole time because the paste is in a constant river coming out of his mouth I can surf S2ki and brush my teeth
Old Aug 21, 2006 | 06:52 PM
CalBear's Avatar
Yeah, I don't leave the sink area because I'd make a mess. Must be a guy thing.
Old Aug 21, 2006 | 10:04 PM
Ash's Avatar
Ash
I brush in the shower so as to avoid having to think of things like this
Old Aug 22, 2006 | 02:57 AM
VTEC_Junkie's Avatar
the foam is caused by toothpaste mixing with water, aided by the scrubbing motion. if you have the habbit of wetting your toothbrush before applying the toothpaste, rinse your mouth with water before brushing, or you salivate excessively when you brush, you will produce more foam. if you don't believe me, try applying toothpaste on a dry toothbrush and start brushing and continue to brush for a couple of minutes. now rinse your mouth clean, wash off your toothbrush, keep the toothbrush wet, apply the toothpaste, and then start brushing and continue to brush for a couple of minutes. you should be producing excessive foam the second time, but not the first time. i personally hate brushing with a dry toothbrush. i feel the foam helps by getting into the crevices to clean spots that the toothbrush brissles can't reach.
to further demonstrate the point. apply some toothpaste to a dry part of the sink and apply some toothpaste to a wet part of the sink. using 2 seperate dry toothbrushes, starting brushing the toothpaste around the 2 respective areas. on the dry part of the sink, the toothpaste would merely smear but will not foam. on the wet part of the sink, the toothpaste should dissolve into the water and foam.
Old Aug 22, 2006 | 04:50 AM
THEOLDMAN's Avatar
Originally Posted by Mindcore,Aug 21 2006, 06:50 PM
I too have thought about this many times... My gf can wander all over the place, as well as those toothpaste commercials they never spill a drop.
I on the otherhand pretty much need a troff underneath me to catch the overflow.
I've tried to keep it all in, but it just doesn't work.
Don't be ashamed my man..
Beard works to keep it from falling all over the place. Using my Sonicare with a microbe of toothpaste helps too.
Old Aug 22, 2006 | 06:10 AM
JonBoy's Avatar
Originally Posted by magician,Aug 21 2006, 04:33 PM
Is it a matter of practice?
That made me choke <laughing>. I don't think anyone else got it, though.
Old Aug 22, 2006 | 07:13 PM
Tedow's Avatar
Uhhh...use less toothpaste?
Old Aug 22, 2006 | 08:54 PM
Amit's Avatar
damn, I always think about this. I've seen people in reals and on Tv brushing without any foam. I too am like a latte. perhaps, it has to do with the size and shape of your teeth, and how much saliva you produce. I don't drull, so it must be the small mouth.
Old Aug 22, 2006 | 11:10 PM
vAnt's Avatar
I don't foam out the mouth and I'm a guy.
I always wet my toothbrush.
