Can someone explain Four Cams
Old Jan 25, 2002 | 11:47 AM
NJTom2000's Avatar
Default Can someone explain Four Cams
I think I understand what an overhead cam is. Even a Double overhead cam. But when I was looking at the specs for the Lexus SC430 that my father is buying I cam to this section on the engine specs:
ENGINE
Designation 3UZ-FE
Type Four Cam, 32 valve V8 with VVT-i
Displacement 4.3 liter, 4,293cc (261 cu. in.)
Bore x Stroke (mm / in.) 91.0 mm x 82.5 mm/3.58 in. x 3.25 in.
Compression Ratio 10.5:1
Horsepower (SAE) 300 hp @ 5,600 rpm
Torque (SAE) 325 ft-lbs @ 3,400 rpm
This information was taken from Toyota's press release website
My question is what is meant by Four Cam
Anyone know?
Tom
Old Jan 25, 2002 | 11:52 AM
gregstevens's Avatar
Banned
I would read that as dual overhead cams...which in a V8 would mean four cams.
magician's Avatar
As a guess: two camshafts for each bank of cylinders, one intake and one exhaust. Hence, four camshafts in toto.
Old Jan 25, 2002 | 11:53 AM
ElTianti's Avatar
V8 = two banks of four cylinders = two cams per bank = four cams
Old Jan 25, 2002 | 11:54 AM
Tex_S2K's Avatar
2 cams on each cylinder bank of the V-8, one for the intake and one for the exhaust. Think of a double overhead cam inline 4.......now double it.
Old Jan 25, 2002 | 11:56 AM
NJTom2000's Avatar
you guys are good.
thanks for the clarification.
Old Jan 25, 2002 | 11:59 AM
Kibro's Avatar
that's when you cam, and then cam, and then cam and then cam again
or living room, bedroom, shower and kitchen...
hehehehe....
Old Jan 25, 2002 | 12:10 PM
jerrypeterson's Avatar
hehehehe....
Amen!
Old Jan 25, 2002 | 12:21 PM
AVXs2000's Avatar
not only V-8 with DOHC are four-CAM.
so is any V-shape of Engines (V4?, V6, V12, V16) and boxer engines (F4, F6, F12) have total of Four-Cam when they are DOHC.
Old Jan 25, 2002 | 12:26 PM
chroot's Avatar
...then wouldn't "quadruple overhead cam" mean the facial moneyshot in a gangbang?
- Warren
Kenn
Mar 28, 2010 06:28 PM
S2000boi
Sep 8, 2001 06:42 PM
The Captain
Aug 3, 2001 10:04 AM
EvilMose
Jul 1, 2001 07:50 PM
