chemistry homework
Old Dec 4, 2013 | 05:59 PM
sandcastle's Avatar
Default chemistry homework
can someone get back to me i need some help with some chemistry homework (i know you s2ki peeps are smart)
you are given the following equilibrium
NH4NO3(s) + H2O (l) --> NH4+ (aq) + NO3-
if we were told that the temp of the solution dropped from the initial measurements to the final measurements,what would these results indicate and where would go place the word "heat"in the above question?
any help is greatly appreciated
the + on NH4+ is a charge and the - on NO3- is also a charge
Old Dec 4, 2013 | 07:06 PM
baZurk's Avatar
Heat would be one of the products on the right hand side of the equation. Since the solution is losing heat, that is one of the products of the initial solution as it changes to the newer state. I believe the loss of one oxygen atom has something to do with that as well.
I am not to sure about chemistry, it all seems like magic to me (and I have a hard Ike understanding any of it)
Old Dec 4, 2013 | 07:09 PM
sandcastle's Avatar
i agree on the magic part. thanks for the help ill take all and any i can get
Old Dec 20, 2013 | 11:23 AM
AZS2KDancer's Avatar
Almost everything looks like magic until you start to understand it. Even to a magician.
Old Dec 21, 2013 | 05:45 AM
darcyw's Avatar
the question is this- is it an exothermic reaction (did the reaction give off heat during the reaction thereby making the surrounding solution warmer) vs an endothermic reaction (did the reaction consume heat energy from that surrounding area during the reaction thereby becoming "colder")
if the temperature of the solution dropped, it means the above reaction took the surrounding heat energy to complete the process. as a result, you need to add heat to the equation on the EDIT- now that i've thought more about it, the heat is liberated on the right side, making the solution "colder".
at least, that would be my understanding.
darcy
Old Dec 22, 2013 | 10:42 PM
magician's Avatar
I'm a magician and chemistry looks pretty straightforward to me.
"+ heat" goes on the right side of the equation. If the temperature drops going from the left to the right, then it has to rise going right to left; i.e., you have to add heat.
Old Dec 22, 2013 | 10:47 PM
magician's Avatar
Where to see the loss of an oxygen atom? All I see is that dissolving ammonium nitrate in water gives you a(n aqueous) solution of ammonium ions and nitrate ions.
brent_strong
Jan 30, 2006 02:03 PM
dc5Racer
Apr 23, 2004 02:38 PM
s2000
Jan 22, 2004 06:30 PM
EVAN_In_A_SPA
Sep 4, 2003 12:21 PM
