CPU ~ water cooled or heatsink-and-fan
Hey All,
I'm in the process of putting together a computer together and decided on an AMD XP1900 or XP1800. The processor runs fairly hot and will require a strong fan. However, along with a stronger fan comes really irritating NOISE. Need some answers to the following questions:
Water cooling:
>How often do you have to refill to water? Or rather, how much maintenance is involved?
Heatsink and fan:
>What's the quiestest fan than you know for this processor?
Any other comments about cpu cooling would be appreciated.
Holman
Water cooling:
Heatsink and fan:
Holman
If you go watercooling, get the DangerMaze II waterblock, it's the best rated out there. Although with watercooling, if you have a closed system, you should put new water and coolant mixture into the system every year.
As for H/S fan, look on: www.3dgameman.com as this guys does a LOT of reviews on heatsink/fan combos
I've got a retail 1800+ (with OEM HSF), a new GeForce4 4600 and 3 hard drives and havent had any problems with heat, even with 80+ degreee ambient temps. The oem HSF should be fine provided you run it at the stock speeds.
