Data base gurus....a question for you
Old Aug 2, 2003 | 01:52 PM
ironwedge's Avatar
Default Data base gurus....a question for you
Anyone know how to link a image map to a Access database?
I'm working on a project in which I'd like to show a neighborhood map (platte map), which of course would be the image map. Then when an individual lot/home site is selected/clicked on the image map it would open the corresponding record in the database. Of course in the database I could go nuts with photos of the house, photos and details of the participating families, etc.
This project does NOT need to be on the net, so I'm really not talking about a dynamic website. At the most it would be nice to distribute the thing on CD, or just share the file.
Also, it doesn't have to be Access (that's just what I'm dumping data into), the real trick is just to link the imagemap to a database record.
Anyone done this?
Old Aug 2, 2003 | 02:20 PM
lehighwiz's Avatar
can the page refresh after the click or do want to do it without a browser refresh?
Old Aug 2, 2003 | 11:49 PM
ironwedge's Avatar
Hmmm, to refresh....or not?
Really doesn't matter, whatever works. Again, I'm really not looking to use it on a server (internet), so it really doesn't even have to use a broswer.
Thanks for the reply & cheers to you -
Old Aug 4, 2003 | 01:42 AM
emc2's Avatar
If you only want 1 picture per record then you could just make a field called "PICTURE" and make its datatype a hyperlink and then link to the picture file you have.
If you have multiple pics you might want to create a seperate table of just picture links and have a ID field on picture table that correspondes to the ID field of the data table.
Old Aug 4, 2003 | 10:41 AM
ironwedge's Avatar
Hmm, that might work. There is only on photo in the record but I'd like to see all the other data fields for that record too (address, phone number, etc).
Ideally, a click on the image map would open the entire corresponding record.
Old Aug 4, 2003 | 12:23 PM
thunderchicken's Avatar
What development language are you working in? Straight HTML? ASP? .NET? php? cgi?
Old Aug 4, 2003 | 01:37 PM
ironwedge's Avatar
[QUOTE]Originally posted by thunderchicken
[B]What development language are you working in?
Old Aug 4, 2003 | 02:32 PM
The Unabageler's Avatar
create a table of the geometric areas of the image map and relate those areas to the record ID of the corresponding house. Postgres has built in geometric data types, that might be useful.
Then when someone clicks, build your sql to join the area table against the house info table based on the coordinates you from the map click.
Old Aug 4, 2003 | 02:34 PM
on the cd, you can include the database, webserver and everything and put a little batch file wrapper around it all. ppl throw in the cd, it starts the database and the webserver and opens a browser to point to the new localhost webserver. very easy, and then it's also a standard interface so should be easier for users to use right away. I'd say that's easier than a standalone app w/ access db.
Old Aug 4, 2003 | 11:03 PM
ironwedge's Avatar
Thanks Josh -
