Does Autocross damage pavement?
Concrete is a brittle solid (meaning it fractures, mostly due to heating/cooling in its case, rocks are extremely weak under tensile forces), and you are mostly applying a shear force going fast across it. Doubt it.
Now if you hit something sticking out of the pavement, the light pole might break a little concrete off, but usually wins in that battle.
I've seen both old and new pavement get ripped up. A local site has requested we stay off the new pavement after it was damaged during an autocross. We lost a concrete airport site because we were pulling up the fill strips between the concrete sections.
Oil + lateral forces = damaged asphault
The autocross itself doesn't damage the lot that much. Over time, as oil leaks from the cars regularly parked on the lot, it will soften the ashpault, then begin to crumble with applied lateral / shear forces. Those crumbles eventually turn in to cracks, and the lateral forces begin splitting into other vectors, and soon you're taking huge chunks of surface out.
Over time, anything will wear out, but the oil accelerates the process by reducing the mechanical properties of the surface.
