Excel Help
Old Mar 1, 2004 | 01:59 PM
AquilaEagle's Avatar
Administrator
Default Excel Help
I'm trying to compare 2 columns of text in Excel to see if the same text appears in both columns or not. So for example I have:
Column A
Apples
Oranges
Pears
Grapes
Column B
Pears
Grapes
I want Excel to show in another column if each is in both, or in just one of the columns, and return some text, like True (if in both columns or False if just in one of the 2 columns)
I'm dealing with 2500 rows of data so need a formula to do it, and that damn paperclip bloke wont give me the answer
I've tried EXACT, IF, OR and AND formulas but cant get them to work
Help appreciated
Old Mar 1, 2004 | 02:05 PM
Administrator
Here's further explanation:
[CODE]
Old Mar 1, 2004 | 02:15 PM
tomunderhill's Avatar
THis may not be the most elegant solution but all I can come up with at moment
Firstly make sure that column B is the longer of the 2 lists (if they are not the same size)
Then sort all column A alphabetically
Then for column C, use a formula like
=IF(LOOKUP(B2,$A$2:$A$4)=B2, TRUE, FALSE)
where A2 - A4 are your range of first set of data (make sure you change this range)
this formula is for C2 - simply copy this formula for all results in the C column
Hope it helps - let me know if you need any clarification
GSi's Avatar
GSi
=vlookup(a2,$B$2:$B$99,1,FALSE)
A2 is the cell you are checking for an occurance of
$B$2:$B$99 is the range which contains the cells you want to search through
1 is the column offset (as your range could be more than one column wide)
FALSE tells it only to return exact matches, otherwise it will return the last value it found before it couldn't find the one it was looking for (relies on the B2:B99 range to be sorted)
Returns N/A if not found
Old Mar 1, 2004 | 02:16 PM
GSi's Avatar
GSi
Great minds..
Old Mar 1, 2004 | 02:28 PM
Administrator
hmm it wont work
Does it make a difference if the 2 data sets are on different worksheets?
Old Mar 1, 2004 | 02:31 PM
GSi's Avatar
GSi
Only to your formula
wanna send me the spreadsheet?
Old Mar 1, 2004 | 02:34 PM
Administrator
YHM
Old Mar 1, 2004 | 08:05 PM
Hustn's Avatar
[QUOTE]Originally posted by AquilaEagle
Old Mar 1, 2004 | 11:21 PM
GSi's Avatar
GSi
Hi Hustn, He got an answer
BTW, there is a flaw in your formula. For it to work the lists would have to be exactly the same (both in content and length). As in AEs example above, if the entries were not on the same line that formula wouldn't spot it.
cat bat false
dog dog true
bat pig false
But it should be true as bat is in the second list.
the VLOOKUP function does this searching of the second list for you, so it doesn't matter where in the list the thing you are looking for is or if they are the same length.
