Excel Help!
Old May 6, 2005 | 02:09 PM
ironwedge's Avatar
Default Excel Help!
Could an Excel guru tell me what function to use, or how to format the function, to multiply a column of numbers (product) by a fixed value? I'm having trouble defining the range of cells in the column, two cells no problem....
It should be easy, 4 columns of 17 numbers (all different) each multiplied by 92.
Thanks!
Old May 6, 2005 | 02:15 PM
ironwedge's Avatar
Doh....never mind. "=K5*92" and drag down.
Thanks for looking
Old May 6, 2005 | 02:26 PM
Austblue's Avatar
Or if you have 92 in a cell, lets say say A2, then you would put $A$2*K5 and then drag down and it would retain that cell
PeaceLove&S2K's Avatar
Yeah, but if you have to use some other constant, it'll be a bitch to change.
Here's what you can do too. Say A1..A100 contains your series of numbers.
You want to multiply them by 92, so put 92 in another cell, say C1.
The results you want to put in B1..B100, just put the following in B1:
=A1 * C$1
(the $ sign means it's constant)
and copy the contents of B1 into B2..B100.
If you later decide to use 93 instead of 92, just change the contents of C1.
HTH
Old May 6, 2005 | 02:27 PM
DOH.
Old May 15, 2005 | 11:48 AM
Filthy Beast's Avatar
The fill handle is your friend......
Old May 15, 2005 | 11:54 AM
exceltoexcel's Avatar
Didn't see this plead until just now.
Excel is my thing!
If you ever need anything and you see me on PM me.
Old May 15, 2005 | 08:52 PM
Incubus's Avatar
Excel is my thing!
Good to know! I will definitely use your skills. By the way, how can I get s2ki to notify me when I get a PM. I used to get a yellow mark next to MyS2K that said "New PMs" or something like that.
Old May 15, 2005 | 11:26 PM
Austblue's Avatar
Are you using firefox? If you are then just add s2ki.com to your allowed pop-ups list and you'll get a pop-up when you have a PM. If you're using a google bar or similar I'm sure that it'd have the facility to give permission to particular sites.
Old May 16, 2005 | 08:49 AM
Incubus's Avatar
Cool, I didn't know about the pop-ups. Thanks.
