Excel question
Old Oct 3, 2004 | 12:57 PM
JerseyGirl's Avatar
Thumbs up Excel question
If I create two graphs using information from an Excel spreadsheet, how can I put both of them together on one graph?
Thanks.
~JerseyGirl~
Old Oct 3, 2004 | 02:12 PM
magician's Avatar
Right click on the graph and select "Source Data". Look at the "Series" tab; it gives you the option of adding additional series to the graph. Click "Add", then enter the title and range for the new graph. Depending on the type of graph you have you may need new abscissa data (e.g., a scatter plot type) or you may not.
Hope this helps.
Old Oct 3, 2004 | 05:01 PM
JerseyGirl's Avatar
What happens if you need a different scale for the new data?
Think of two bell-shaped curves, one centered around 3 and the other around 15. If the original graph only has the bottom "scale" going from 0 to 6, how can you get it to expand?
Old Oct 3, 2004 | 07:08 PM
magician's Avatar
I'd say that the best thing to do is plot the original as a scatter plot, where you specify the data for the x-coordinates as well as for the y-coordinates. When you add the new data as I outlined above, you'll put in x-coordinates and y-coordinates for the second curve, and the scale will adjust to the new data.
Let me know if this helps.
Old Oct 4, 2004 | 04:05 AM
mns2k's Avatar
Scale changes automatically depending upon range of values.
Old Oct 4, 2004 | 04:28 AM
tokyo_james's Avatar
Can you not set different scales for each set of Data when you only have 2 sets? I am pretty sure that you can ....
Old Oct 4, 2004 | 05:33 PM
exceltoexcel's Avatar
<---- This is why I have this screen name
Two bits of info for you
You can manually set the scale by right clicking the axis select format axis select scale un check the boxes for max and min and ennter your own scale
If so some strange reason you would need to superimposed on scale on anouther, for what reason I have no idea since then you should just creat two graphs, you can format both the chart area, plot area and walls to area->none Making all of the back ground transparent and then placing the graph on top of one. make sure you set it order to front. If you need any further assistance or a better clearification of the steps please feel free to PM me.
You can set two different scales for a graph one for the primary axis and one for the secondary! Some graph types do not support the secondary axis
Downgear
Jan 15, 2009 06:43 AM
jah
Oct 19, 2008 07:43 PM
flitcroft
Mar 30, 2005 08:56 AM
