Help with deleting a file in WinXP
You have to get to the command line of your windows XP system. To do this you need to do
START>RUN
then type in CMD in the box and click OK
before this though make sure the only files you want to delete in that directory are the ones giving you problems.
I need to know what directory those files are in something like:
C
rogram filesmovie_maker
When you get that directory and you have the command line window open then you will need to change to that directory manually:
cd C
ath to file
then issue the command
del *.*
this will delete everything in that directoy
I am assuming that you are using Windows XP correct?
START>RUN
C
rogram filesmovie_makerWhen you get that directory and you have the command line window open then you will need to change to that directory manually:
cd C
ath to filethen issue the command
del *.*
Did you get to the command line?
you should see something like this:
C:windows>
that is when you would issue the command
cd D:directory to file
then your promt will look like
D:directory of file>
then you can do del*.*
MAKE SURE YOU ARE IN THE DIRECTORY
if you issue the del *.* in the wrong directory everything in that directory will be gone
C:windows>
OK what folder on your D: drive is the file under?
If you can get to this then you are in the right spot
C
ocuments and SettingsAlex>
once you get here
you type
cd D
IRECTORY THE FILE IS IN
CD=CHANGE DIRECTORY
to get a list of the directories on your D: drive type dir and hit enter
What folders do you click on once you bring up your D: drive to get to the file? This is called the path. We need the path to this file to manually delete it.
Is this file or files the only thing in its directory (folder)?
Tell me what you would normally click on in Windows XP to access this file. This should give my your path.
C
ocuments and SettingsAlex>once you get here
you type
cd D
IRECTORY THE FILE IS INCD=CHANGE DIRECTORY
Ya man, I got that part.
It's under
D:Alex's Stufftemp
It ain't working though. I'm telling you, it won't access my D: directory.
I can navigate the C: directory just fine, but not the D: directory.
It's under
D:Alex's Stufftemp
