Material engineers: input needed
Old Mar 26, 2003 | 05:33 PM
mingster's Avatar
Default Material engineers: input needed
I'm looking for a new product line and currently looking for a kind of plastic that is (of course) injectable, with VERY strong torsional strength capabilities. Another application is I'm looking for plastics that can replace steel to reduce weight but with similar "strength" if you will.
If you know of any exotic or new plastic blend, please let me know.
Old Mar 27, 2003 | 05:11 AM
JonBoy's Avatar
Would you mind first explaining (in very general terms) what you're building (PM me if need be)? The size or intricacy may mean some plastics can't easily be used. Even general dimensions would be helpful. I'm looking into a few things that you might be able to use - I'll reply again shortly.
Old Mar 27, 2003 | 05:14 AM
JonBoy's Avatar
Do you need good impact resistance? Thermal stability? Any machining required? Water absorption a big issue?
Old Mar 27, 2003 | 05:23 AM
JonBoy's Avatar
Check out this link and the company itself - they're pretty comprehensive with the plastics.
Nylon
Nylon 46 - Bridges the price-performance gap between traditional nylons and high performance materials. Suitable for both extrusion and injection molding, Nylon 46 offers a range of functionality including extensive UL classifications and specialized wear and bearing grades.
Noryl
Old Mar 27, 2003 | 10:32 AM
1a-race's Avatar
Banned
IMO go with www.smooth-on.com the best product I've worked with is c-1508 as far as pourable plastic goes.
Old Mar 27, 2003 | 10:40 AM
JonBoy's Avatar
1a-race: I believe those would work for making molds, but from what I gather, mingster is looking to use the plastic IN the molds (ie, inject it into a mold), not for making the molds themselves. The plastics you show have a tensile strength of under 4500 psi for most - that's anywhere from 1/6 or less than the tensile strength of most steels. It can't even remotely replace steel for strength and I would warrant it's even weaker in torsion or flexure.
Old Mar 27, 2003 | 11:07 AM
1a-race's Avatar
Banned
Good point, I use the above mentioned product for mold making however I use what they call featherlight for the actuall piece. It is possible to use the 1508 in both, I've done it but my product doesn't warrant the need for it. BTW it is rated at 11,200psi. I am really interested in what he has to make in plastic but as strong as steel.
Old Mar 27, 2003 | 11:56 AM
Muz's Avatar
Muz
Former Sponsor
How about Kevlar?
Old Mar 27, 2003 | 12:09 PM
adelaide's Avatar
JonBoy and 1a-race, what do each of you do?
I work with and develop a lot of plastic product and both of your knowledge is pretty impressive.
Just curious.
Old Mar 27, 2003 | 12:47 PM
1a-race's Avatar
Banned
Just curious.
It is top secret until the release of the product next week but i'll give you a hint, it has to do with the s2000.
