Oh shit! Check this!
Holy crap, that is amazing. It took me a long time to figure out if they meant to do that or not because I didn't read the captions as I went. Craziness!!!!!!
Luckily I didn't see any ppl on the boat or flying off as it was tilting.
the Tugboat story
It was at the old Rooster Bridge at Demopolis, Ala. It happened in April, 1979. The pilot rode the boat through. When he saw he could not kill the tow out before hitting the bridge, he sent the crew onto the tow. He tried to back the face wires out but one fouled and the tow dragged the boat into the bridge were the wire finally broke. Some local just happened to have a camera at the right time.
April 28, 1979- the CAHABA, Capt. Jimmy Wilkerson, was dropping 2 of his 4 barges thru the east span of Rooster Bridge- mm 200.(something), with intent of running around thru the lift span and catching them below. Pilot Earl Barnhart was on the tow helping the 2 deckhands take off safety wires, winch wires, etc. Wilkerson under-estimated current, and got too close to the bridge, and for some reason they had taken loose all rigging except the stbd. tow-knee wire. This wire pulled the stbd. tow knee under the bridge, and when it broke, the towknee popped up and hung in the bridge steel. Now he's stuck, and the current laid the CAHABA onto the bridge, stbd. side to. When the lower port deck went awash, the vessel rolled, went through the span, and came partially back up once it cleared. Capt. Wilkerson remained at the sticks; however, at one point he was straddled the stbd. pilot house door frame, and the port front pilot house window blew out, filling the place with water.
The boat with the blue trim you see is the CATHY PARKER; she was waiting above for her turn. The CATHY radioed to the TALLAPOOSA, who was down the reach below Blacks Bluff, that something had happened to the CAHABA. Capt. Gary Grammer tied off the TALLAPOOSAs tow, and light-boated to the CAHABA, where he pushed her out into a flooded corn field. The stbd. 16-149 of the CAHABA was still running. The TALLAPOOSA then rescued the 3 crew members, and secured the 2 loose CAHABA barges.
The photographer was from the Linden, AL DEMOCRAT, en route to Meridian, MS, and happened to get caught as the CAHABA blew for a draw at the Rooster bridge. What kept these pictures out of circulation for so long (we believe) was that the President of Warrior & Gulf, owners of the CAHABA, bought the negatives immediately after they were published in the LINDEN DEMOCRAT. I have a copy of the original published version, although it's a little worse for wear after 23 years.
What righted the vessel? She had just topped off with fuel at Demopolis, 14 miles upstream. The CAHABA has one central fuel tank fwd. the engines; had that tank been 1/2 full, she might have never come back up.
Earl Barnhart passed away sveral years ago. I have no idea where Jimmy Wilkerson is.
If you have a copy of the original newspaper I would love to obtain a copy of it for the company that owns her now. She is presently named the M/V Captain Ed Harris and still runs today.
Most of the old bridges on the Tombigbee happen to be built in bends ( Rooster, in the old days, Naheola mm. 173, and Jackson RR, mm 89.0) On Rooster and Naheola, during extreme high water, it was easier ( and safer) to get next to the east bank, out of the heavy current, and ease your tow through the span closest to the bank, where the current wasn't so fierce, than trying to drive or flank the tow through the lift span of a draw bridge, with 150' or less of horizontal clearance. So the idea was to "drop" (cut loose) the barges through the slack water span, run light-boat through the draw span, and catch up to the barges just below the bridge. If you had a good deck crew, and winches whose brakes wouldn't lock up on you at the worst possible time, this procedure took about 15 minutes. At Jackson RR bridge you don't have a choice, as there is no "alternate" span to get the tow through; you either run or flank it in high water.
Capt. Wilkerson was attempting this procedure when, in the words of a great Tombigbee river pilot "the music was playing faster than he could dance to..."
The incident occured at the old rooster bridge (US HIGHWAY 80), mile 202 on the Tombigbee river. The bridge was blown out and replaced by a new bridge just up river in the early 80's. There is a wood chip loader on the sight of the old brige now. The river was at a record highwater stage. If I remember correctly the gage was around 73 feet at Demopolis. A normal low water gage is around 13 feet.( They measure the gages on the Warrior and Tombigbee differently now so you may have seen higher numbers.) It has not been that high before or since. Point of interest: The now imfamous M/V Mauvilla which belonged to the same company picked up the Cahabas's tow and carried it on to Mobile.
This text was from my guestbook by Bjarne v, thank you !
A friend of mine tracked down the following account of the Tug Boat photos. It's interesting to read the story behind the photos.
This occurred on April 28th, 1979.
The river is the Tombigbee River and this happened to be the record high water ever for that area. The towboat you see coming down on the bridge is the Motor Vessel Cahaba owned by Warrior Gulf Navigation out of Mobile, Alabama. Warrior Gulf is a subsidiary of Pittsburgh Steel.
If you are familiar with Birmingham, Alabama's coal mines and steel mills, this is one of the companies that would haul iron pellets up to Birmingport and off-load to make steel plate. On the return the barges were filled with coal for export at the McDuffie Coal Terminal at the mouth of the Mobile River and at the head of Mobile Bay. The Bridge was the Old Rooster Bridge (since demolished and removed - I saw the explosion to tear it down also) located below Demopolis, Alabama. The land-side highway dead ends at the bluff, and you can still drive to this site and imagine how high the river had to be to get to the bottom of the bridge...
The pass or Channel Span of the bridge the ships use to navigate was located on the far West side of the river, or on the opposite bank from the photographer's standpoint. In normal river flow, we would drop down near the rock bluff and steer through the opening to pass southward with our tows of coal barges. Normal loads were six barges, each measuring 195' X 35' and loaded to a 10' draft. This allowed each barge to carry approximately 2,000 tons of coal (times six = 12,000 tons X 2000 pounds = 24 Million pounds of cargo.) The boat is 1800 Horsepower twin engine diesel built in Pine Bluff, Arkansas. It is named after one of the eight "friendly" Indian tribes. It is the Motor Vessel Cahaba. At the "sticks" or helm is Captain Jimmie Wilkerson, a long time river pilot and was my personal friend - since deceased.
The river current was so very treacherous that we were forced to drop down to the bridge in the slack(er) water on the left descending bank and when we got down to the bridge, we uncoupled the boat from the barges and let the barges drift down under the bridge. The bottom of the bridge would "shave" the coal stacked in the barges off to a level surface. The next step was to back the vessel upriver and then go over to the far West side and traverse the bridge's channel span with the boat, and run down and catch the barges. It was just too dangerous to try to bring the barges through the bridge span in the current.
Anyway, Jimmie dropped down properly and with the entire rest of the crew standing on the barges for safety, he began to reverse his engines to back away. His stern would have to be kept directly pointed into the current or the boat would travel sideways like a kite without its tail. Captain Jim was a fine pilot, but he made a small mistake and his stern was caught in the current, twisted sideways and the river smashed him into the bridge sideways. Notice that the boat re-surfaced right side up on the down stream side. What luck you say? Nope, WGN ballasted all their vessels with three to four feet of cement in the bottom. The boat was like a little yellow rubber duckie, and came back up like a duckie oughta do. The boat suffered major cosmetic damages, but little flooding because of water tight doors, except in the pilothouse. Notice the picture where the boat is not quite righted and you can see water pouring out of the wheelhouse door. The chair washes out, and Jimmie told me he was holding on to the controls with all his might to keep from going out the drain and into the river. Everything was washed out of the bridge except for the Captain and one life preserver. He was very shook up and you can see him approach the tow of barges downriver. Well he didn't get it together quite soon enough and he smashed into the barges, causing further damage. Shortly thereafter, the Motor Vessel Cahaba was laid up in storage where it remained until purchased by Madison Coal, re-powered, refurbished and re-named the Capt. Ed Harris.
I next saw Jimmie about a month after this and we had a cup of coffee together and talked about the incident. He was smoking a Camel Non-filter but didn't even need an ashtray because his hands were still shaking too much for the ash to build up to any degree.
How do I know all this? I was on the boat that went through the bridge immediately before the Cahaba. The Motor Vessel James E. Philpott made the bridge and was headed south at close to 15 MPH. For all you who don't understand, that is very fast on a commercial towboat with that much tonnage. Glad to pass this on to everybody...
Captain Michael L. Smith
AWESOME!!!
Capt'n to the bridge!
