pressure washer
Old Mar 9, 2005 | 04:48 PM
emrillive's Avatar
Default pressure washer
i don't know what its called but its green and its all over my cement floor. From the tons of raining. Its everywhere and its nasty as hell, i need to get a pressure washer and get this cleaned up.
anyone recommend a affordable pressure washer that has good power?
Old Mar 9, 2005 | 05:13 PM
BOOSTLOVER952's Avatar
If your not going to use it often then you might want to rent one. It should only cost around $40 to rent.
Old Mar 9, 2005 | 06:08 PM
SgtSaunders's Avatar
HomeDepot rents em
But look out, once you use one you will think of all sorts of uses. I got one and know I cant live w/o it.
I bought a Northstar at www.northerntool.com
3000psi 6HP Honda gas engine I originally bought 120V version and it kept popping my 15A breaker.
Old Mar 9, 2005 | 07:28 PM
NFRs2000NYC's Avatar
Just make sure you learn your nozzle tips. Some can cut right through a stone. Also, pressure washers are NOT good for pavers or any kind of joints that are cemented or grouted. The pressure chips at the stuff, and eventually, will wear it down all the way.
Old Mar 10, 2005 | 05:55 PM
^^^what he said
Also, make sure you are very careful when changing nozzles. I misjudged a nozzle's lock-in and pulled trigger. Next thing I know nozzle's missing. Dammit!
2 weeks later my neighbor (with a knowing grin) tells me he found a "brand new" nozzle in his garden over 100 ft away!
A loose nozzle can become a dangerous projectile.
