Pro-Steroids: Mag 10 and Tribex?
Has anyone used Mag 10 and Tribex?
I've read all the good and bad, and never really know what to believe from either side, I'd like honest opinions from those that have used or know people who have used them.
Is it really that much better to use Tribex after Mag 10 (as opposed to not using mag 10 only), and why?
Side effects?
did you notice any benefits?
Side effects?
Well, the goal obviously would be a balance between gains and negative effects, I'm not really keen on the idea of acne, hair loss, small testes, a limp tool or a bad kidney... which is why I'm asking.
if you wanna go the OTC (over the counter) route then check out this site ....they sell everything at a fraction of the cost with flat 4.95shipping....heard mag 10 is good but costly...instead of Tribex try Tribestan by Sopharma....one box will last 10 day so buy about 4-5box's @ $20 each...it is completely natural and holds the top spot for tribulis....I used to be a GM for Bally's and have seen it all...for something all natural you will actually feel the results...now for a prohormone mag 10 is fine....maybe try Ergopharm's 1-AD along with any kind of 4-androdiol.....hope this helps
[QUOTE]Originally posted by PDX S2000
Aspirin and caffeine (or Midol to us gals...) may reduce the severity of some of the short-term side effects that are felt by hormone levels that are changing, but I can't see them affecting the overall hormonal balance in a person, male or female.
what are you looking to accomplish?
the best way to increase the desired hormonal ouput wold be to use some kind of GH enhancer (Healthy 'n Fit makes the best).
Otherwise, go for veterinary grade stuff. Those, although illegal, give you the best results.
sounds like he want to stay OTC.......there is a huge difference between prohormones and the real deal......yes the real deal used properly can keep the side effects to a minimum but it's the long term that you need to consider...I am not arguing either side.....but I think PDX s2000 is looking for some advice on OTC and not juice......are you considering juice, if so you need to educate your self on them first....if not then you can try the couple of things that I mentioned earlier
OTC - I just want to gain size.... already do my best to eat a ton of protein, cabrs and have used creatine here and there... it's not that I'm not happy with the results, I am, but if something OTC will possibly speed things up I'm interested in trying it, if the negative effects aren't terribly bad.
Thanks for all of the advice guys/gals. I appreciate it.
