Stupid Question About RPMs...
Its simple physics imo - Work = Force * distance. 2,000 rpms in 1st gear = 2,000 rpms in 2nd gear.
The drive gear ratio is the only thing that changed, and that is outside the engine. Thus the wheels move at a higher rate because of the drive gears not the engine - the same amount of work thus propels the car faster, but the engine isn't working harder.
When you have someone jump on your back, you're changing the weight of the person in the example, but the car doesn't get heavier just because you shifted into 2nd. You're thinking of variables that include gravity and friction. They do come into play, but that does make the argument less clear, so to keep things simple, think low speeds, no elevation changes.
changes.
changes.
at higher gear, there's more air resistance. ergo more force (remember a = 0), hence more work.
Originally Posted by GT_2003,Sep 5 2007, 08:02 AM
if the question is, "does it take more power to maintain 4000 rpms in 4th gear than in 1st," the answer is yes, the engine must make more power to maintain 4000 rpms in 4th. If the question is, "does the engine make more power at full throttle in 1st than in 4th or vice versa" the answer is no.
Sure, the car will slow down when you start to coast at 4k rpm in any gear, but thats because of friction, and you have to overcome higher friction the faster you go, but that's working harder to acheive the rpm because you are accelerating against friction, the engine isn't working harder once you stop accelerating.
Imagine you are driving down hill, where the slope of the hill allows gravity to negate friction. In this case, when you coast at 4k rpm, the pull of gravity negates the pull of friction. The hill will need to be steeper at 4th gear, 4k rpm than at 2nd gear, 4k rpm, because gravity needs to negate more friction, but these are all external factors to the engine. Going down these hills, and engine is not working any harder at 4k rpm in either gear, and it does not have to accelerate to get to a speed where 4k rpm reside.
