What's the difference between bolts and screws?
Old Jan 19, 2003 | 06:53 PM
Otter's Avatar
Default What's the difference between bolts and screws?
The other day, a bunch of coworkers and I were arguing about the difference between a bolt and a screw.
I always thought that a bolt used a nut and a screw used a threaded part.
A coworker started declaring it having to do with the length of the threaded portion, etc.
The more I looked on the web, the less I believed anything I read.
Anyone know from an authoritative source what the difference is?
Or pure conjecture, as long as it is stated
Old Jan 19, 2003 | 06:59 PM
Fear Itself's Avatar
I'm no expert, but I think of a screw as something that "bites" into the material it goes into, while a bolt is inserted into something already threaded to match.
my .02
David
Old Jan 19, 2003 | 07:19 PM
xviper's Avatar
A screw holds by its thread in the material it has penetrated.
A bolt "usually" has a nut on the opposite side of the material it goes through and this is what keeps it from coming back out.
And to add a further complication:
A bolt can be a screw but a screw can't be a bolt. (eg. Lag bolts.)
Old Jan 19, 2003 | 07:21 PM
xviper's Avatar
Oh, and it sounds kinda silly to tell someone to go "bolt" themselves!
Old Jan 19, 2003 | 08:24 PM
TrojanHorse's Avatar
Another way to look at it (always exceptions of course) is that if you have to use a screwdriver on it it is a screw. If you use a wrench or socket, its a bolt.
Old Jan 19, 2003 | 09:03 PM
seung's Avatar
[QUOTE]Originally posted by xviper
[B]A screw holds by its thread in the material it has penetrated.
Old Jan 19, 2003 | 11:14 PM
Sondra S2K's Avatar
A screw has a pointy end, a bolt doesn't. Also, bolts use nuts... literally, this kind of screwing doesn't involve nuts
Old Jan 20, 2003 | 04:27 AM
xviper's Avatar
Additionally, you can eat "nuts and bolts"!
Old Jan 20, 2003 | 11:48 AM
S2000boi's Avatar
screw eats thru materal when the thread cuts it.example would be putting a screw to hand something in wall.
bolt would be the bolt thing so u can hold ur front bumper on. bolt requires a nut n usually has washer to go with it.
Old Jan 20, 2003 | 12:11 PM
4IGS2000's Avatar
Spammer
That is an interesting choice of words, remember kids the difference between a screw and a bolt is...
a screw eats thru material when the thread cuts it and a bolt...
How about this: screws are self-tapping, while a bolt is not.
