Windows NT Experts?
Old Sep 20, 2002 | 12:05 PM
DC5 Kid's Avatar
Default Windows NT Experts?
I know there is way to make drive c: about 8 gb on Windows Nt..but just can't remember how to?
ANy Suggestion?
Old Sep 20, 2002 | 01:33 PM
rstark's Avatar
Huh? How big is it now? How many drives do you have and what size are they?
Old Sep 20, 2002 | 01:57 PM
mingster's Avatar
if you were doing it from scratch i don't know if you could - i remember the partition limitation on NT when installing from a CD boot was 4GB (?) sorry, i haven't installed one in years and forgot. of course you can partition any size after that...but that's not C drive...
Old Sep 20, 2002 | 02:03 PM
DC5 Kid's Avatar
i made drive c: 300 mb..install nt and sp5 and make drive d: 7gb ntfs...and delete drive c: and reinstall nt on drive d...which will become drive..once i delete drive c ...
It's working:
My Drive C is now 7.27 GB NTFS
Old Sep 20, 2002 | 02:04 PM
rstark's Avatar
Ah, take a look here for the answer: http://support.microsoft.com/default.aspx?scid=kb;en-us;Q119497
Old Sep 20, 2002 | 02:05 PM
Schatten's Avatar
I believe what you are referring to is the file system choices. If you want it to be a large size, then you have a few options, but... let me explain how it works and why there is a limitation.
FAT16 - limit of 2GB in space
FAT32 - the limit is well... WAY UP THERE
NTFS - the limit is up there as well.
HOWEVER, upon installation of the OS, which I assume you are doing - if its a FRESH INSTALL, then the limitation will be 4GB for NTFS installation. Is this where you are going? If so.. that 4GB is made from VFAT (virtual fat16 w/64k clusters instead of 32 that fat16 uses). This is used to install the OS onto a FAT16 partition and then convert it to NTFS afterwards.
If you use FAT32 you do not have this problem.
If you take the drive and format it/partition it out on another system you will not have this problem.
Hope this helps.
Old Sep 20, 2002 | 02:07 PM
DC5 Kid's Avatar
i got it working...now
Old Sep 20, 2002 | 02:21 PM
Relson's Avatar
with NT4 sp5 i ran into an issue with C: partitions >7.87GB (? or close). The systems would randomly lose the boot sector, and the OS was toast. There is a KB article about this "feature".
Bottom line, don't make the boot partition be larger than ~7.87GB.
Old Sep 20, 2002 | 09:45 PM
Otter's Avatar
Partition Magic does the trick
Old Sep 20, 2002 | 10:12 PM
Schatten's Avatar
that's something I prefer to stay FAR FAR FAR away from. believe me, I've cleaned up a fair share of issues over the yeras that PM created.
