crazy offsets only...
Old Nov 10, 2009 | 07:52 AM
  #3101
AMBAICAR's Avatar
haha i have the same problem with mine it will also be fixed soon over winter break it hurts me 2 but i look at it as an opportunity to get the fenders flaired professionally
Old Nov 10, 2009 | 08:23 AM
  #3102
Antonov's Avatar
Can quarter panels be fixed without bondo?
Old Nov 10, 2009 | 08:29 AM
  #3103
midwesta's Avatar
I think so, but it definitely requires paint.
Old Nov 10, 2009 | 09:13 AM
  #3104
Whitefire818's Avatar
If you have the money you can always have a body shop weld on more metal and flare it out or do whatever you want. Expensive but then even if you rub the metal will flex whereas bondo/frp etc.. will just crack.
Old Nov 10, 2009 | 09:23 AM
  #3105
Dreaming_S2k's Avatar
Even if they flex larger dents out, heat shrink the sheet metal, sand it down, reprime, etc...usually they still put at least SOME fiberglass filler in and block it down real thin in order to make it as smooth as possible.
As far as rear fenders from excessive rolling...methinks they could possibly sand it all down and heat shrink the metal a little bit and probably do it * almost * no fiberglass.
In my experience, the less fiberglass = the more skilled the bodywork.
Old Nov 10, 2009 | 08:02 PM
  #3106
jdm98specdc2's Avatar
I have some ssr professors that used to be on my 350z. You think I can use em on a stock height s2k?
17x8.5 35 offset front 225/45/17's
17x8.5 30 offset rear 245/40/17
Old Nov 10, 2009 | 09:07 PM
  #3107
butcher43366's Avatar
i think anything fits on a 4x4 s2k
ya they should fit, but im no wheel expert, anyone else chime in?
Old Nov 11, 2009 | 01:13 AM
  #3108
need input asap guys, i have the tires currently off... i was thinking about mounting em on thursday, but dont want to waste my time or money if it wont fit. btw i will be lowering my car at least 2" soon as well
Old Nov 11, 2009 | 01:20 AM
  #3109
alexisthemovie's Avatar
yes it will fit
Old Nov 11, 2009 | 01:24 AM
  #3110
chViETnk's Avatar
your gonna need fender work to get those to fit depending on how low you go but it is possible.
