crazy offsets only...
Old Mar 23, 2010 | 11:24 AM
  #4251
s2sik's Avatar
Old Mar 23, 2010 | 02:44 PM
  #4252
Whitefire818's Avatar
Originally Posted by rushinxpress,Mar 23 2010, 08:17 AM
Hey guys quick question. I am about to buy a set of rims and I wanted to ask if I what size tires i can go in the front and rear with out rubbing or pulling / pulling fenders.
Offset: +16 +22
Also Will I need a camber kit and if so what camber?
Or my second set up would be 17x8.5 et 33, 17x9.5 et 45.
Would a 17x8.5 et 33 fit in the front with no rolling or pulling?
I am dropped about 1.5" on Tein Coilovers.
Thanks.
Sorry Search is down.
Read through this thread then if you still have questions come back.
Pretty much all offsets, sizes, camber, etc... have all been answered in this thread at some point or another.
Old Mar 23, 2010 | 03:13 PM
  #4253
PsykotiK's Avatar
Offset: +16 +22
Thanks.
im gonna be nice and answer these for u
you would have to run pretty small tires to fit those without rolling or pulling.. standard 215/245 would be proper tires for those
no camber kit needed.. stock camber adjusters are fine
all those sizes will need a roll and a small pull unless u wanna start cheesing fenders.. its always a good precaution to go ahead and roll your fenders
Old Mar 23, 2010 | 03:28 PM
  #4254
alexisthemovie's Avatar
run 225 and 205 on the 16's
Old Mar 23, 2010 | 03:46 PM
  #4255
rushinxpress's Avatar
I think ill go with the set of 17's and do a roll.
Thanks Guys!
Old Mar 23, 2010 | 08:45 PM
  #4256
Thanks Guys!
235/255 would fit nicely on the 17's
Old Mar 24, 2010 | 04:47 AM
  #4257
ccdan's Avatar
Not sure if this has been posted up. Made these for a customer a few weeks back.
CCW LM20: 18x10F 245/35/18 18x11.5 285/30/18
More: Flushstance.com
Old Mar 24, 2010 | 04:52 AM
  #4258
nte11igence's Avatar
^ beautiful.....
high on my list for my next set of wheels
Old Mar 24, 2010 | 07:24 AM
  #4259
crank's Avatar
Originally Posted by ESCALVANTE,Mar 15 2010, 05:34 PM
My front fenders have been pulled and flared quite a bit. My front fenders are flared to about a 45 degree angle from the OEM point while my rears were pulled so much that the rear quarter panels caved in.
With the 17x9.5 +40 SSR Type Fs wrapped in 255/40 all around:
I easily have about an inch worth of clearance front and rear with 2.0 degrees camber up front and 2.5 degrees camber in the rear.
With the 18x10.5 +38 Kranze ERMs wrapped in 295s front and rear:
I barely have any clearance in the back and the front needs at least another 1 degree of camber to work.
Hope that helps.
NTO1 255/40/17 all around with 2.75 degrees camber up front and 3.25 degrees rear camber:
hey wat wheels are these again, slipped my mind...
Old Mar 24, 2010 | 07:32 AM
  #4260
nichigo's Avatar
SSR Type-F's...he mentioned it in his post.
