crazy offsets only...
Whats up fellas.... I just purchased a set of 18x8.5 +42 and 18x9.5 +45. Going to have my fenders rolled in the next week and I am not wanting to run crazy amounts of camber but up to -3 degrees is fine. Any help on tire size would be much appreciated and should I get the guy to pull a little also if he can on the front and rears? Oh yeah i am lowered on tein s-specs and have a set of koni yellows that I need to install also just trying to get the fitment lined out first.....Thanks
Heres my rota fighters 17x9 et35 rear with a 5mm spacer so et30.And my new wheels which are 17x9 et35 rear with a 25mm spacer so et10. Not fitted yet, more lows to come and some slightly wider tyres on the rear. They have a 195/40 on at the moment which is a little too stretched but I'm going to go for a 205 section so that I can still get them under the arches.
Need some quick advice, before pulling the trigger.... 18x9.5 et25 squared setup. What's needed to fit on a S? Considering I'm rolled front and rear, plus tab relocate. What size tire all around, and what else is needed to fit them?
Serious question. I was really interested in some wheels, but they only come in 18x9.5 and bigger, so I was going to go for a Square set-up of 18x9.5 +30. Not completely sure what tires yet, but maybe 225/35r18. I wanted to know if this will fit reasonably. I plan on buying Downforce fenders in the near future, and they are +30mm, so I figured they will fit relatively easily, but I wasn't sure about the rears. I understand that I will need to fender roll, relocate rear bumper tab, and camber. Anything else? What is everybody else doing for the rears?
