Ohio S2000 Club Ohio S2000 Owners Club
Coilover Question
Old Jul 3, 2006 | 06:46 PM
Reddog21's Avatar
Default Coilover Question
Does anyone know if Bilstein PSS9 coilovers will fit on an AP2? On their website they only show fitment for AP1.
If they do fit an AP2, does anyone know a reputable shop to buy some from? Midwest Performance?
Old Jul 3, 2006 | 07:12 PM
Popeye's Avatar
Yes.......and yes
Old Jul 3, 2006 | 08:25 PM
soundzero's Avatar
Chris,
PSS9 should fit AP2. Only difference between AP1 and AP2 suspension is spring rate, swaybar tickness and such. Suspension geometry didn't change at all as far as I know thus PSS9 for AP1 should fit AP2 cars.
Old Jul 4, 2006 | 05:44 AM
ROGUE3308's Avatar
Chris, we'll talk later today... when this weather clears up.
We'll get you taken care of. Brandon's shop can handle the order and install. I would call or e-mail the company and verify they fit the AP2.
Old Jul 4, 2006 | 06:01 AM
Popeye's Avatar
Unless the Bilstein mounts are different from.....Koni,KW,Tien,Moton,Penske,Mugen,Spoon,Sho wa(which is Honda OEM),or T1R they will fit.
Old Jul 4, 2006 | 06:07 AM
Reddog21's Avatar
Thanks for the help! I am thinking this will be the next mod on the rod and I wanted to make sure they were compatible before I got my heart set on them.
David1's Avatar
They are all the same as soudzero stated.
Old Jul 4, 2006 | 06:57 AM
soundzero's Avatar
Oh Chris, make sure you get the halfshaft spacer if you lower the car significantly.
Old Jul 4, 2006 | 07:53 AM
thetz99's Avatar
Be aware you use the hats off of your stock suspension.
Old Jul 4, 2006 | 08:43 AM
efthimios's Avatar
they'll work....that was the set I bought 2 months ago for my AP2
