Battery Recommendations?
Hey guys its time to change out my battery... I just came back from LA and its not getting enough juice and this isn't the first time it has happen. (Me being lazy in getting a new battery after a few times this has happened
But yeah just seeing what you guys are using as a replacement for the OEM battery. I was considering a Hawker Genesis or the OEM. Any other brands good out there or that you have experienced? Hoping to spend around 120 or under
). But yeah just seeing what you guys are using as a replacement for the OEM battery. I was considering a Hawker Genesis or the OEM. Any other brands good out there or that you have experienced? Hoping to spend around 120 or under
Originally Posted by LoudMusic,Oct 7 2009, 11:55 AM
My car has had unusual starting problems a couple times in the past couple months. I don't think it's battery, but I've been meaning to ask about batteries too.
OR
Could be this service bulletin.
Service Bulletin
© 2009 American Honda Motor Co., Inc
February 6, 2009
02-053
Immobilizer System (Type 4)
VEHICLES AFFECTED
2006–09 S2000
All of the vehicles affected have a Type 4 immobilizer
system that disables the vehicle unless a programmed
ignition key is used. The Type 4 system is different
than previous systems in that the transponder ID code
in the key is a rolling-type code instead of a set code. In
this service bulletin, a programmed ignition key refers
to a transponder-type key that has been cut to fit the
ignition switch and whose transponder ID code is
recognized by the immobilizer system. If you try to start
the engine without a programmed ignition key, the
engine cranks, but it does not start.
I can get you more info on that if you need.
NRG Cell Original Battery - 11.5 lbs (http://www.heeltoeauto.com/ - Marcus is a good guy.)
Had it for 2+ years now w/o any issues.
Triple-H
92
Apr 13, 2011 11:06 AM
