Show n go issue
Old Apr 6, 2011 | 09:52 PM
vtecb's Avatar
Default Show n go issue
Got my show n go today and installed it but for some reason it's not working properly.... Right at the point it should flip down it hangs up and stops. I'm not sure If I doid something wrong or not and when my hood is closed it doesn't seem to get good signal strength with the key fob.... Any help anyone?
Old Apr 6, 2011 | 10:30 PM
MegaPower's Avatar
your rail is bent.
I have no problem with the signal tho.
It can go pretty far.
Old Apr 7, 2011 | 04:34 AM
VintageMac's Avatar
I agree. It sounds like the unit is binding. Maybe when you tightened the mounting screws it pulled something out of alignment. Did it work OK before you mounted it?
I get good reception with my remote - never had a problem. Try repositioning your antenna.
Old Apr 7, 2011 | 07:42 AM
vtecb's Avatar
I got the signel working better. But still catching I mighy try to mount it different
Old Apr 7, 2011 | 11:57 AM
MegaPower's Avatar
i mount my receiver right in front of the fuse box.
Old Apr 7, 2011 | 03:33 PM
vtecb's Avatar
It worked fine when b4 I mounted it. It seems like there's too much weight on the end if I life up on it it works fine
Old Apr 7, 2011 | 04:20 PM
Rev. WAR's Avatar
if you get it working i wouldn't mind taking a look at this in person...as I'm considering one now...
Old Apr 7, 2011 | 08:10 PM
vtecb's Avatar
So it works to this point then stops.... So for me works precut haha
Old Apr 7, 2011 | 08:21 PM
MegaPower's Avatar
dont forget to flip it up when u pass a drive way
Old Apr 7, 2011 | 09:13 PM
vtecb's Avatar
No kidding I forgot fistthipng this morning
