where can i get a CAI installed?
Old Nov 7, 2010 | 10:28 PM
200implants's Avatar
Default where can i get a CAI installed?
I'm looking for someone/someplace to help me install my K&N FIPK. Any suggestions?
Old Nov 7, 2010 | 10:42 PM
exodusx7x's Avatar
Im assuming this is a 15 minute job with some normal hand tools? Most CAI are pretty straight forward. But if you want a shop recommendation Try forged performance
Old Nov 7, 2010 | 11:05 PM
boostftw's Avatar
Just did one this weekend for a friend. It takes a bit longer on a slammed car since you jack it up to remove the undertray and front bumper for a CAI install. If your in Beaverton Portland Speed Industries is closer. Heres there info if you don't want to install it yourself.
PSI
6103 NW Casper Place
Hillsboro, OR 97124
(503) 431-1395
Old Nov 7, 2010 | 11:27 PM
chubbychu's Avatar
If you can find your hood latch, you can most definitely install the FIPK!
Old Nov 8, 2010 | 01:16 AM
#172CR's Avatar
sunil! I'd be glad to help you install the k&n. I put one on my laguna and CR. It's nothing too hard :-) I'm in beaverton too.
Old Nov 8, 2010 | 07:47 AM
Tony_05s2k's Avatar
Way to be a helpful had Ira
CAI should be pretty simple.
Old Nov 8, 2010 | 09:18 AM
#172CR's Avatar
Sunil one thing I forgot, we do need to drill a hole into the elbow and get an appropriately sized rubber grommet. The airflow sensor has to be inserted into the sleeve. It should have directions on the install sheet as well. Just let me know man,
503-957-8260
Old Nov 8, 2010 | 11:10 AM
Thanks everyone!!! Going to order one now.
Old Nov 8, 2010 | 12:15 PM
s2sik's Avatar
for ira
Old Nov 8, 2010 | 01:30 PM
Webfoot's Avatar
The FIPK is super easy to install. I just installed mine this year and took about 30 minutes.
My advice would to read the follow threads before installing.
https://www.s2ki.com/forums/index.php?showtopic=256141
http://s2khowto.com/guides/fipk2/index.html
I also found that the instructions provided by K&N in "My" kit were wrong on two vacuum hose connections. However the above links had everything right.
No drilling was required, and no S2k's were harmed during the installation.
Good Luck!
