Orlando The I-4 Parking Lot
How Difficult
Old Aug 7, 2009 | 06:16 PM
Mrwilliams's Avatar
Default How Difficult
Im ordering a TP soon, and i was wondering how hard is it to difficult is it to install?
and also, do i NEED to get it tuned, or will the ecu just adjust to it right away?
TIA
Old Aug 7, 2009 | 08:30 PM
Subalahoo's Avatar
TP isnt that hard to install. an hour at most if you got the know how
Old Aug 7, 2009 | 09:18 PM
highwaystardoritos's Avatar
soak the nuts (hehehehe) on the cat over night, it will cost you less grief in the morning when you are going to install the TP
Old Aug 7, 2009 | 09:46 PM
Mrwilliams's Avatar
^^jajaja,
but...what should i soak them in? i've never done anything to any of my cars, so my mechanical knowledge isn't that vast at all. thanks for the input guys
Old Aug 7, 2009 | 11:17 PM
Ryuu's Avatar
spray them with like wd40 or some penetrating oil..
Old Aug 8, 2009 | 03:51 AM
RadioZero's Avatar
if you've never done anything to your car, i hope you know that a test pipe will make your exhaust smell bad.
a berk high flow cat is a better option and it's better for the enviroment.
Old Aug 8, 2009 | 06:51 AM
Bandiscoot's Avatar
Originally Posted by Mrwilliams,Aug 8 2009, 12:46 AM
^^jajaja,
PB Blaster FTW!
Just be careful when you spray it ... because spraying it onto a hot cat may cause it to ignite
definitely do this with a friend if possible ... working with a friend is better
Old Aug 8, 2009 | 08:54 AM
thraak's Avatar
I installed the Berk test-pipe along with a Fujitsubo exhaust. I have never had a cel (check engine light). Originally, I thought that it was going to smell bad but it doesn't.
FWIW: Mine was a 2005 so my nuts didn't need a soakin'
EDITED: Berk BT-1601 63.5mm test pipe with built-in O2 CEL fix.
Good Luck,
Thraak
Old Aug 8, 2009 | 11:47 AM
speedworksracing's Avatar
What test pipe did you get? If it doesnt have a CEL fix built in you have to make one.
Old Aug 8, 2009 | 12:01 PM
Mrwilliams's Avatar
haha mine is a 00' so im sure it will need some TLC
yeah, i would never do something like that on a hot car
thanks for all the input guys. i actually just found a diy for a test pipe from berk, so thats REALLY perfect
