ALIGNMENT RECOMMENDATIONS
Old Jan 16, 2007 | 02:54 PM
s2kpinoyboy's Avatar
Default ALIGNMENT RECOMMENDATIONS
Hey whats up guys. just wanted to find out what shops can do alignments. Any recommendations?
Well it all started on my way to school, i slid into a curb like 5mph in my Daily driver (Civic Hatch) and hit my right front tire. After a few minutes, i notice that my car was not steering as well. When i go straight, i have to steer slightly to the left.
Old Jan 16, 2007 | 03:05 PM
mikegarrison's Avatar
Any tire shop should be able to align the car so it drives straight. Search this site for more details if you want a (more expensive) performance alignment. But first, check the suspension. It could be that the alignment bolts just gave way, or it coule be that you have bent the suspension arms and have more work to do than just an alignment.
Old Jan 16, 2007 | 03:23 PM
BowlofRice's Avatar
tru-line in bellevue and fordahl motorsports in kirkland come to mind. they are around 120 for a custom alignment.
Old Jan 16, 2007 | 04:21 PM
Thanks guys any more?
Old Jan 16, 2007 | 04:56 PM
HeyDanNiceShot's Avatar
The dealer. Usually around $80. Curbs like to bend lower control arms and tie rods; hope it's not the case for you.
Old Jan 16, 2007 | 05:16 PM
BB APone's Avatar
^^Like mentioned above, something could be bent, could be anything from the hub,spindle,tie rod, control arm. I'd recommend you get your suspension checked out first considering civics has only toe adjustments. So if you get the toe set and it still pulls, I'm almost positive that something will be bent. I know from experience because I do alignments everyday at work.
Old Jan 16, 2007 | 06:05 PM
okay i'll check that out too. I am running Koni yellow with Omni camber kit Control Arms
FearlessFife
Oct 3, 2011 09:00 AM
tehsu
47
Mar 22, 2010 06:57 PM
XtymourX
Aug 28, 2005 03:37 PM
christy
Jul 31, 2003 07:04 PM
