Help with headlight diffusers?
Old Jul 3, 2008 | 01:04 PM
j0nathanl3e's Avatar
Originally Posted by WyattH,Jul 3 2008, 07:10 AM
love you, jon!
what's your schedule like for the next week or so? and would your place work? pm me if you'd like.
you gotsa PM Wyatt
Old Jul 4, 2008 | 08:36 AM
bcs's Avatar
bcs
I'm gonna have to wait until after my wedding (no extra spending right now), but if you guys can do a little write up on your steps, it would be much appreciated. =)
Old Jul 4, 2008 | 11:22 AM
I'm sure we can snap some pics of the process
Old Jul 4, 2008 | 12:00 PM
WyattH's Avatar
Old Aug 22, 2008 | 05:56 PM
w1ngman's Avatar
Originally Posted by vspc2nr,Jul 1 2008, 08:40 PM
stick it in your oven, 350* is good. wear gloves cause its stickey as hell, dont pry it all at once, a little at a time is all is needed.
Okay...or how about accepting advice of 225 degrees. And remember to select BAKE (*NOT* broil ). Do each headlamp for two sets of 12 minutes. After first set of 12 minutes, pull out of oven long enough to unfasten the various attach/tabs. As mentioned, handle hot headlamps with a pair of 'mechanics gloves' etc. Return headlamps into oven for 2nd 12 minutes. This time, when you remove them, they'll separate nice and easy. Swap diffusers, etc. Then reverse process noted above to reassemble. Once cooled, add a bead of silicone sealant around the join/seam and you'll be golden.
Of course, all this advice may be of little use...if you've already cleared them now .
- Dave
Old Aug 22, 2008 | 06:46 PM
lig's Avatar
lig
For you youngsters - w1ingman is the headlight baking guru on the board.
Old Aug 22, 2008 | 06:58 PM
jerrypeterson's Avatar
[QUOTE=lig,Aug 22 2008, 07:46 PM] For you youngsters - w1ingman is the headlight baking guru on the board.
Old Aug 22, 2008 | 06:59 PM
lig's Avatar
lig
Originally Posted by jerrypeterson,Aug 22 2008, 06:58 PM
Showing your own youth?
Last I checked, I was credited for the oven-bake procedure on http://www.RickS2k.com. You know, the guys that make the diffusers.
Touche'
I should say the commercial baking guru. My bad.
Old Aug 23, 2008 | 12:49 AM
WyattH's Avatar
I chickened out... keeping Amber.
New-in-box clear diffusers/sidemarkers FS.
Old Sep 4, 2008 | 02:48 PM
blkwidow's Avatar
Chicken!!!
Mine are in the oven as I type this.
