help with rotors...
Old Jul 7, 2010 | 02:37 PM
xilict's Avatar
Default help with rotors...
hey, im changing my brakes and rotors an need some help. my situation is i got the calipers an such off an those 2 little screws out but the rotor itself wont budge, is it supposed to be that hard to take off? i tried hammering it an it wont move. thanks in advance.
Old Jul 7, 2010 | 02:45 PM
S2KVtecftw's Avatar
spray some lube on the center bore and hit it from the back and rotate till it comes off.
Old Jul 7, 2010 | 02:47 PM
xilict's Avatar
thanks for quick reply ima give that a try.
Old Jul 7, 2010 | 02:58 PM
xilict's Avatar
sweet got it lol.
Old Jul 7, 2010 | 02:59 PM
mikegarrison's Avatar
Next time, especially if you don't have any lube, just use a bigger hammer. Deadblow hammers work best for this kind of thing, because they don't bounce back and hit anything else.
Old Jul 7, 2010 | 03:15 PM
jerrypeterson's Avatar
Failing that, just drill the heads off the screws. I tracked the car for six years without them. But if you are stickler, the replacement screws are probably a lot cheaper than the brain damage or tools to save the rusty ones.
Old Jul 7, 2010 | 05:45 PM
When I first read it, I thought that was the problem. But he already had removed the screws. He was just afraid of bashing on the rotor hard enough to break it loose.
Old Jul 7, 2010 | 06:17 PM
xilict's Avatar
yea those 2 screws came out easy with an impact driver, i just needed to hit the rotors harder to pop loose.
Old Jul 7, 2010 | 07:42 PM
street_ruler's Avatar
put your purse down and hit it like a man
Old Jul 7, 2010 | 11:43 PM
Seattle2k's Avatar
