I refinished some wheels
A little curb damage,
During the sanding process
All done.
Sprayed
They look alot better in person, i will take better pictures once i have the tires mounted.
All done.
Sprayed
Did you try to replace the material you sanded off with filler, or did you just sand them down until they were smooth then paint them? If the latter, is the fact that that part of the rim isn't flush with the rest noticeable?
Sausa8e: no tools needed, I used 60Grit, and took it down by hand.
PedalFaster: There wasnt a need to add any aluminum, the curbage wasnt that deep. aside from a little nick or two you cant tell that the wheel was repaired.
Sentravq: I picked them up for 550, the 18.5/19lbs isnt horrible for a 8 and 9.5 wide wheel. it wont hurt anything once i install the gt35r.. hehe
The paint was some dupont bc/matte cc i had left over, artic white W243.. i accidently reduced it too much but it didnt run.
