Need Extra Eyes
Old Jun 5, 2008 | 01:41 PM
blkwidow's Avatar
Default Need Extra Eyes
I just need some opinions here. I recently installed some Skunk2 springs on MY00. The front is higher then the back, which I read was normal. I also read that some people switch the springs around so the front is lower then the rear. Should I go through the effort to switch the springs around, or does my car look ok? Sometimes I can be critical so I just wanted to hear from others. I need to fiqure out what I'm going to do soon because I need an alignment now. Here are some pics.
Here is a before pic...
[Here are the afters...
Thanks for the help in advance.
Old Jun 5, 2008 | 01:45 PM
vietshiet501's Avatar
i personally think it looks weird because the rear is tucked and the front looks stock. but i also read that switching front and rear makes it drive weird. but i just got s2000 4 months ago so dont quote me on this.
Old Jun 5, 2008 | 02:16 PM
RT's Avatar
RT
Ray, it looks good to me!
I don't think swapping frt to rear is a good option since the rear spring rates are higher than the fronts ..... you swap them around and it's going to push like a pig.
Old Jun 5, 2008 | 02:32 PM
Seattle2k's Avatar
was the suspension properly loaded, before everything was tightened down? People who neglect this step usually complain about the front being higher!
Old Jun 5, 2008 | 03:04 PM
j0nathanl3e's Avatar
you have a reversed rake now
you should definitely try loading the suspension and tightening everything to spec if you haven't done so.
Old Jun 5, 2008 | 03:19 PM
RT's Avatar
RT
good point!
Old Jun 5, 2008 | 04:29 PM
blkwidow's Avatar
I've done everything to spec. I'm going to go over it one more time this weekend. Thanks for the opinions guys. Maybe the Greddy lip will hide the wheel gap once I get it back from National Auto
Old Jun 5, 2008 | 04:40 PM
I miss that lip already
So then you did load the suspension?
Old Jun 5, 2008 | 07:01 PM
wingle69's Avatar
do you bottom out?
Old Jun 5, 2008 | 08:17 PM
phizzak.s2k's Avatar
that doesn't look right. do you have a side picture?
