In need of help w/ broken wheel stud
Old Jun 21, 2007 | 06:21 PM
j0nathanl3e's Avatar
Default In need of help w/ broken wheel stud
I was a victim of a broken wheel stud yesterday. It happened when I was mounting my wheels. This was the first time I tightened my lugs without my torque wrench, and unfortunately that was all she wrote (my torque wrench broke not too long ago). I guess I overtightened it without knowing. Only the tip of the stud broke off, so the remaining stud is almost flush with the rim.
Has anyone ever replaced a stud before? I bought a wheel stud from Honda this morning and I don't want to attempt to remedy the situation pretending to know what I'm doing. Also, do I absolutely have to replace the bearing?
All the lugs are now torqued back to factory spec, thanks to my buddy's torque wrench.
-Jon
Old Jun 22, 2007 | 07:02 PM
fperra's Avatar
I recently replaced all of mine because my HRE wheels needed longer studs. And yes, I replaces the bearings. I suggest you should plan on replacing all the studs when you do the job just to be safe.
Old Jun 22, 2007 | 10:59 PM
Yeah, I figured I'd have to replace the bearings along with it. Probably will end up replacing all the studs to be on the safe side. Thanks.
Old Jun 24, 2007 | 09:51 PM
mikegarrison's Avatar
That's what I would recommend. You have to do 90% of the work to replace one stud; might as well do the other 10% and replace the other four at the same time. Ditto for the bearing.
s2nasty03
Jul 5, 2015 10:23 PM
fatbaldboy
May 16, 2014 07:43 AM
Greg W
Jun 19, 2012 06:38 AM
nartnailuj
Dec 15, 2011 11:55 PM
s2kjunkie
Aug 19, 2004 06:08 AM
