Shocks/Struts?
Stock shocks work ok for a wile, the rear is already under dampened on the S though and gets more pronounced with the firmer springs, and of course the more miles you put on them.
The Koni Yellows are a popular damper option which I believe offer you a 4 way damping adjustment, stock height and 1/2 lower perch for additional lowering. I think you will appreciate the damping adjustment for tuning with your aftermarket springs.
They do get noticeable under dampened by then, rebound specifically) stiffer springs also exaggerate that condition. At 70k, I’d consider saving yourself the hassle and just do the damper change along with your springs now.
The koni's as I mentioned. If you cant afford those right now, then you will have to run your stockers. Nothing cheaper available that will actually give you an improvement in ride with your springs.
I don't know what you mean by 4-way adjustable, but you can adjust rebound. Compression is fixed. Rebound is "infinitely" adjustable within the range of the shock, meaning you don't have set levels of rebound that you adjust to.
I'd agree with Jerry on this one, stick with stock stuff. If the ride becomes too bouncy for you, then think about upgrading shocks. You shouldn't need to though, save your money.
Originally Posted by ALFYonso,Apr 21 2010, 07:44 PM
Underdamped according to who?
