wheel upgrade ?
Old Jul 22, 2013 | 09:07 PM
Manga_Spawn's Avatar
Site Moderator
I know I just don't want it to turn into that. It does sort of sound like a wtb at first.
Old Jul 23, 2013 | 04:46 AM
Tampa s2000's Avatar
Correct not looking to buy looking to compare different options. I understand that tire choice and brand along with size does have a big difference on ride quality.
My main question was the appearance and filling of the wheel wells as the first priority based on size as well as brand of wheel and tire choices. My main thrust is to not modify anything that cannot be returned to stock.
Old Jul 23, 2013 | 08:54 AM
s2000Junky's Avatar
So if I’m understanding correctly you will not be rolling fenders- stock untouched fenders front and rear, correct?
My question to you would be what tire widths F/R would you prefer to utilize? This will narrow down the wheel options. Fyi - 18" have a wider tire availability if that is important. Cost and weight goes up though too of course over 17". If maximizing tire width isnt as important to you then I would recommend sticking to 17" wheel/tire options.
Old Jul 23, 2013 | 09:29 AM
Site Moderator
Hmm so you don't want to roll fenders and you will or will not be lowering the car? I think you need to stick to 17's with offsets close to AP2 OEM. So basically the higher the better. Enkei has the PF01 that comes in S2000 specs. You should also stay close to the OEM staggered setup so 7.5 or 8 in the front and 8.5 or 9 in the rear.
Old Jul 23, 2013 | 09:35 AM
Jet3010's Avatar
In addition to what has already been said, be sure to check this guide out as well:Wheel Fitment Guide
I'm going to agree with Manga on the PF01 being a great wheel for zero fender work. They look great, come in multiple colors, and have good widths with high positive offsets.
Old Jul 23, 2013 | 10:23 AM
Site Moderator
And they are about as cheap as you can get with a quality wheel.
Old Jul 23, 2013 | 11:25 AM
s2000Junky's Avatar
Just fyi - You can get a 285/30/18 on a 10.5" wide wheel at +70 to fit in the rear without rolling fenders, which is why I posed the question. The front not nearly as much and requires some considerations. 17" rim your pretty much stuck in the 255/40 zone.
Old Jul 23, 2013 | 01:42 PM
Thanks for your feedback I will do a little research.
Old Jul 23, 2013 | 04:01 PM
Site Moderator
Is this actually true is you are staying on stock suspension? Also I have seen S2000's with 18's and stock ride height and it looks terrible. Spend some time looking through the gallery and reading. I will say not rolling your fenders severally limits your choices but there are options.
Old Jul 23, 2013 | 05:07 PM
s2000Junky's Avatar
Stock ride height or lowered, doesn't matter. Several local guys have run them in the long long past. A couple newer sponsors on this site are finally catching up to the times, problem is you have to spend real money to get wheels in these widths and offsets. 285/30 10.5 +70 is the absolute limit on stock untouched rear fenders.
One local goofball example from a different era
https://www.s2ki.com/s2000/topic/301...1#entry5799916
